Go to Post the best way to make things most unfair is to have different rules for different people. - Jack Jones [more]
Unread 17-02-2012, 17:23
compboy07's Avatar
compboy07 compboy07 is offline
AKA: Jake M.
FRC #2449 (Out of Orbit)
Team Role: Electrical
compboy07 is on a distinguished road
Re: Can't read joystick values in Java
The getX() method is for the kinectStick. Use getRawAxis(int axis) or getAxis(Joystick.AxisType.kX);
Unread 17-02-2012, 17:51
nubie nubie is offline
FRC #2734
nubie is an unknown quantity at this point
Thank you for your fast reply. I tried switching to using the getRawAxis method, but it still does the same thing. I try:
// I also try 1-6 instead of 0
leftMotor.set(leftDriveStick.getRawAxis(0));
When I put in 3, the motor drives at full speed, but for everything else it does not drive at all. In either case, I can't control them with the joysticks. Am I missing something else?
Unread 17-02-2012, 19:10
compboy07's Avatar
AKA: Jake M.
Try two things: firstly, output your values using the LCD display class; it helps a ton. Also, try the getAxis, as it has an enum instead of the index. Instead of some arbitrary number as an argument, it uses Joystick.AxisType.kX
Unread 18-02-2012, 13:11
FRC #2734
I managed to find the default code project that was missing from the libraries on a different thread, and when I ran that, it worked. I still do not know what the root issue is but maybe I will be able to determine it in the future.
Thank you for your help.
Unread 18-02-2012, 18:14
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
No, getX() is inherited in both Joystick and kinectStick from GenericHID.
Look in the libraries at Joystick.java and you'll find
     * Get the X value of the joystick.
     * This depends on the mapping of the joystick connected to the current port.
     * @param hand Unused
     * @return The X value of the joystick.
    public double getX(Hand hand) {
        return getRawAxis(m_axes[AxisType.kX.value]);
     * Get the Y value of the joystick.
     * @return The Y value of the joystick.
    public double getY(Hand hand) {
        return getRawAxis(m_axes[AxisType.kY.value]);
TL;DR getX() works for joysticks, not just kinectSticks.
