Go to Post Freshman: "Why did it break?" Another Freshman: "Because we don't know what we're doing!" Veteran Student: "This is why we can't have nice things." - MechEng83 [more]
Unread 17-02-2012, 18:56
dwmcc dwmcc is offline
FRC #2192 (YAK Attack)
dwmcc is an unknown quantity at this point
Re: On Button press, run a sequence (Not momentary!)
Originally Posted by Alan Anderson View Post
The Flat Sequence structure is a natural for sequences of events. Each frame of the sequence will run in turn as the previous frame's functions complete. Put one in a neverending While in the Periodic Tasks vi, and make the first frame wait for the button press.
Thank you both for your reply. Alan, I have inserted my code into the Periodic Tasks vi in a neverending while loop, but how can I tell it to run it when I press the joystick button?
Thanks!
dwmcc
Unread 18-02-2012, 00:33
Try this.
Name:	solenoid sequence.png
Unread 18-02-2012, 14:21
Try this.
Thank you so much! Worked perfectly.
Unread 19-02-2012, 12:27
gabrielc97's Avatar
gabrielc97 gabrielc97 is offline
AKA: Gabriel
FRC #4029 (Spartan Bots)
gabrielc97 is an unknown quantity at this point
[quote=Alan Anderson;1129266]Try this
how can i program this to control a motor?
Gabriel
Unread 19-02-2012, 12:52
Pirate programe's Avatar
Pirate programe Pirate programe is offline
FRC #0354
Pirate programe is an unknown quantity at this point
[quote=gabrielc97;1130131]
Try this
Change the DIO VIs to MotorControl VIs, with parameters controlling it as you need to?
Unread 19-02-2012, 13:03
gabrielc97's Avatar
AKA: Gabriel
[quote=Pirate programe;1130143]
Thanks! we'll try that.
Gabriel
