Go to Post Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking. Raul - Raul [more]
Unread 17-02-2012, 19:51
bakalove bakalove is offline
FTC #4285
bakalove is an unknown quantity at this point
Multiple problems
We have a problem with our light. We have tried wiring in all kinds of different ways, but we cannot get the light to power on. For some reason the negative current that connects to the light has no current.
Another problem were having is we cant get the camera working and were not sure why it goes green and it seems like its working but it doesnt send images back to the driver station.
Unread 17-02-2012, 19:58
dotbran dotbran is offline
AKA: Brandon Olsen
FRC #3219 (TREAD)
dotbran is on a distinguished road
Re: Multiple problems
Light issue:
Post an image of how it's wired at both the light and the sidecar
Camera issue:
If your camera isn't hooked up to your radio (i.e. You're using the second port on the cRIO), do that now. Make sure DHCP is disabled in the settings of the router and the camera (You'll need to go to your camera directly to set the IP; if you reset it it will be 192.168.0.90. If that doesn't work for the driver station you can also try allowing anonymous viewing in the camera settings.
