Go to Post You mean how many Edible Data Analysis Metrics and Aggregated Measurable Entities (EDAMAME)? - Andrew Schreiber [more]
Unread 17-02-2012, 16:07
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Weird Problem
Hi, we are encountering a very strange problem..(Again)
Yesterday our code was working fine, but today in the morning when we added in our compresor code EVERYTHING STOPPED WORKING!, we get communication we can deploy our labview code successfully we didnt change anything at all (software/hardware). Everything as in: the Launcher, ball grabber, all autonomous modes, everything!::S
We get the following errors in Diagnotics panel:
FPGA_DIOReadPWMValue.vi>> BuildDashBoard Data.vi >> Robot Main.vi
<Time> 14:58: 50 02/12/2012
FRC: The <b> Digital MOdual </b> is invalid or not found. Make sure to set <b> Digital Modual </b> to either <b>Digital Modual 1 </b> or <b> Digital Modual 2 </b> and ensure the modual is plugged into the spot you specified.
Please take a look at our code
Please and Thank-You
ID:	11955  Click image for larger version
"A team back in training !"
Unread 17-02-2012, 17:54
bstites82 bstites82 is offline
AKA: Blake Stites
FRC #2164 (multiple)
bstites82 is an unknown quantity at this point
Re: Weird Problem
if your compressor loop is in teleop then the loop never exits and hangs up robot main. I would suggest simply using the compressor pallet tools provided to create code like http://www.chiefdelphi.com/forums/sh...d.php?t=102830
Unread 17-02-2012, 20:13
dotbran dotbran is offline
AKA: Brandon Olsen
FRC #3219 (TREAD)
dotbran is on a distinguished road
Re: Weird Problem
What the?
Why don't you just use the provided Compressor VIs?
Unread 17-02-2012, 21:33
Re: Weird Problem
You may want to modify the Build Dashboard VI to use the correct slot. There was an issue in the template where the slot is the wrong integer. I think you delete the +1 node.
Greg McKaskle
Unread 18-02-2012, 14:31
FRC #1514 (Vikings)
Re: Weird Problem
Hi, we fixed the problem by doing that but as soon as we did that we got this error:
ERROR <code> 1097 occurred at Call Library Function Node in FPGA_SystemOpen.vi -> FPGA_SystemAsync VI Agent.vi
Edit: When we press run we also get " Teleop is not in memory. :" But its there! :S This also made our autonomous stop working :S Also It counts till Teleop Instance(6) or so. :S Why?
