Go to Post Battle Bots and other robot fighting competitions is to First Like McDonalds to Hamburgers They get the idea, and have the taste, but they are bad for you in the long run. - Conor Ryan [more]
Unread 05-02-2012, 22:33
JMR15RTC JMR15RTC is offline
FRC #2534
JMR15RTC is an unknown quantity at this point
BALL DENSITY
Has anyone else noticed alot of variation in the density of the balls. When we shoot with all variables the same on the shooter some of the balls shot vary a great deal in distance. Our shooter is back to full speed for each shot and nothing else has changed. We are thinking it is a difference in the density of the balls. Anyone else have any thoughts? Thanks!
Unread 05-02-2012, 22:49
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: BALL DENSITY
The biggest issue seems to be that the new ones have a skin and almost hold air like a regular rubber ball. after some handling, the skin gets lots of little holes and the ball compresses much easier and more quickly.
2016 Central Illinois Winner. Curie Division finalist
Unread 06-02-2012, 15:58
NJEchoAlpha NJEchoAlpha is offline
AKA: Nathan
FRC #1334 (Devils)
Team Role: Webmaster
NJEchoAlpha is an unknown quantity at this point
Re: BALL DENSITY
We tested, and the balls are varying slightly in weight and the weight is not evenly balanced throughout the ball.
Unread 06-02-2012, 16:18
Nathan Pell's Avatar
Nathan Pell Nathan Pell is offline
FRC #0233 (The Pink Alliance)
Nathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to behold
Re: BALL DENSITY
Yes, we measured the three from the kit and two others we got from AndyMark and they vary about 20%. It is very frustrating.
Florida First
Unread 06-02-2012, 17:43
Yankeefan181's Avatar
Yankeefan181 Yankeefan181 is offline
1540 Co-Captain
AKA: Tucker
FRC #1540 (Flaming Chickens)
Yankeefan181 is a jewel in the roughYankeefan181 is a jewel in the roughYankeefan181 is a jewel in the rough
Re: BALL DENSITY
We noticed that a few of the balls compressed a lot more than others and thus it's going to be interesting to see which teams can handle that and which can't. This is all very frustrating.
Tucker Gordon
Team 1540: The Flaming Chickens
Co-Captain
Drive Coach
Manager: Competitive Analysis
Co-Manager: Mechanical Engineering
Unread 17-02-2012, 13:55
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: BALL DENSITY
We had the same experience. We had three roughed up balls and one new one. The three shoot well but the new one launches with twice the distance
At the regionals they will probably start out with new balls which will gradually soften until one is destroyed and they put in a new one. That will be fun........NOT
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 17-02-2012, 14:42
Re: BALL DENSITY
What you describe is not a variation of density. The ball is still roughly the same volume and mass.
The title of the thread should be "Coefficient of Restitution"
Google it.
Unread 17-02-2012, 20:41
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
Re: BALL DENSITY
This is one of the challenges of this game. The best way to get away from this is to design a shorter that takes this problem out of play. Almost everyone with a wheel shorter is going to have a problem with this.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 17-02-2012, 20:48
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Re: BALL DENSITY
We toyed with the idea of putting in a piston to squish the ball and measure deflection and then changing wheel speed to suit each ball.
