Re: Weird Problem
You may want to modify the Build Dashboard VI to use the correct slot. There was an issue in the template where the slot is the wrong integer. I think you delete the +1 node.
Greg McKaskle |
Re: Weird Problem
Hi, we fixed the problem by doing that but as soon as we did that we got this error:
ERROR <code> 1097 occurred at Call Library Function Node in FPGA_SystemOpen.vi -> FPGA_SystemAsync VI Agent.vi Edit: When we press run we also get " Teleop is not in memory. :" But its there! :S This also made our autonomous stop working :S Also It counts till Teleop Instance(6) or so. :S Why? Last edited by whcirobotics : 18-02-2012 at 15:46. |
