Go to Post the golden rule of robotics for the 21st century: Do unto robots as you would have them do unto you - KenWittlief [more]
Unread 17-02-2012, 21:56
Re: Programming Case Structure for Kinect Code
Originally Posted by Mark McLeod View Post
Most of the Kinect vi's have a "success" output that should be usable for this.
According to the LabVIEW help, success means it got data from the kinect server (which implies it would return success even if the kinect isn't plugged in). Have you tested the success flag with and without the kinect plugged in?
Another option would seem to be the Kinect Header vi which returns the number of players.
Unread 17-02-2012, 22:06
Good point, I looked at it early on, but don't remember when success was true or when it was false.
# players=0 sounds good.
Inspect the available outputs to see which one will work for you.
Unread 17-02-2012, 22:17
I believe it is the Kinect header that returns the Version String. A numeric value indicates that all is well and otherwise the string contains messages such as No Power.
Greg McKaskle
