Go to Post i wish ours was done so i could get some sleep - keagara [more]
Unread 17-02-2012, 23:19
obot obot is offline
FRC #4181
obot is an unknown quantity at this point
Help Please!(Rookie Team)
I am looking for basic java programming code to turn on and off compressor. I have power from compressor connected to a spike relay per rules. I understand how to talk to a Jaguar, but believe that I plug PWM from spike into digital sidecar relay slots. IS this correct and if so please send a simple program that will use joystick(2) buttons 10 and 11 to turn power on and off to compressor using spike.
Thanks a million. NEAL
and or anyone else that can help
Unread 17-02-2012, 23:42
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Help Please!(Rookie Team)
I don't really know the electrical side of things here, but I do know that there's a pretty simple method for using Spike relays: the Relay class.
Basically, you initialize one with the required port and the direction:
Relay relay = new Relay(PORT,direction); // direction can be Relay.Direction.kFoward,Relay.Direction.kReverse, or Relay.Direction.kBoth
Then you set it to one of four options (but it will throw an InvalidValueException if you set it to a direction it isn't configured for):
relay.set(Relay.Value.kOff); // 0v-0v, any direction
relay.set(Relay.Value.kForward); // 12v-0v, kForward or kBoth
relay.set(Relay.Value.kReverse); // 0v-12v, kReverse or kBoth
relay.set(Relay.Value.kOn); // 12v-12v, any direction
Unread 18-02-2012, 00:23
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Correction:
relay.set(Relay.Value.kForward or kReverse)
Should be
relay.setDirection(Relay.Direction.kForward or kReverse, or kBoth);
Hope this helps! Happy Competitions!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 18-02-2012, 08:46
Ginto8's Avatar
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Originally Posted by NS_Radication View Post
Correction:
Should be
setDirection() tells it what directions it CAN go in, while set() tells it which direction to actually go. If you're only setting your relay to Value.kOn or Value.kOff, then setting the direction is ok, but it still isn't a good idea because the relay is reinitialized and its value effectively set to kOff on every call to setDirection.
I'm getting all my info about the relay from the source (from sunspotfrcsdk/lib/WPILibJ/src/edu/wpi/first/wpilibj/Relay.java in this case), in case you want to check my info
Unread 18-02-2012, 14:30
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Correction:
Should be
As much as I love your avatar, I have to say you're wrong on this. .set() is what actually sets the value of the relay, .setDirection() is just the possible directions it can be set. Many a screwup on our team has been caused by mixing those up.
Unread 18-02-2012, 16:29
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
There is a compressor method that handles the relay for you.
Compressor(int pressureSwitchChannel, int compressorRelayChannel)
is the constructor for a Compressor. It reads the pressure switch and handles the compressor relay.
Compressor compressor = new Compressor(1,1);
compressor.start();
is enough to get the compressor started. It will automatically be stopped when the pressure switch tells it to.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 18-02-2012, 21:27
Iron Drakes Iron Drakes is offline
FRC #4181
Iron Drakes is an unknown quantity at this point
Awesome, but where does the code go ?
Unread 18-02-2012, 23:09
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
You can add that code in the constructor.
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 19-02-2012, 16:43
jase728 jase728 is offline
AKA: Jase728
FRC #3210 (Falcons)
jase728 is an unknown quantity at this point
if (!airCompressor.getPressureSwitchValue())//check if the compressor is working
airCompressor.setRelayValue(Relay.Value.kOn);
else
airCompressor.setRelayValue(Relay.Value.kOff);
^^^ You also need this in the continuous function
"In theory there is reality, but in reality there is no theory" - Erich Keane (FRC 2010 Build Season - Team 3210)
Unread 29-02-2012, 00:28
Fletch1373's Avatar
AKA: Fletch
else
no you don't... if the Compressor object is constructed properly, it will handle turning itself on and off automatically based on the pressure switch value.
Student:
Mentor:
Volunteer:
2016 Tour:
