Go to Post There's too much whining lately.. we need a hug forum - Gadget470 [more]
Unread 17-02-2012, 23:49
Kohala2460's Avatar
Kohala2460 Kohala2460 is offline
AKA: Michael
FRC #2460 (Na Paniolo)
Kohala2460 is an unknown quantity at this point
Robot drives with drive code, then doesn't with more code.
Our situation is that we are driving 4 CIM motors on 4 Jaguars in Module 1 ports 1,2,3,4. We have programmed it to use the Gamepad and use the left joystick to control it with "Arcade style."
Once we add in 2 more ports in module 1 to control an additional 2 jaguars on right joystick. (Shooter1, Shooter2)
1. Shooter doesn't work
2. Drive only drives at "1" or max speed.
Unread 18-02-2012, 23:22
Re: Robot drives with drive code, then doesn't with more code.
Please double-check the 12 volt power input to your Digital Sidecar. Verify that all three power LEDs (BAT, 5V, 6V) are brightly lit. Tell us what your Robot Signal Light is doing, both when things are working and when they are not.
Unread 19-02-2012, 15:51
ethen155's Avatar
ethen155 ethen155 is offline
AKA: Ethan
FRC #1831 (Screaming Eagles)
ethen155 is an unknown quantity at this point
If that doesn't work, then sent me your code and i might be able to tell you what is wrong with it(if it is in the code).
