Go to Post but eventually it seems that we realize that there's an I in FIRST, and the I stands for Inspiration, not for "me" - MrForbes [more]
Unread 17-02-2012, 21:04
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
STOP Day and electronics
ISTOPING will check later on tonight, but can you keep electronics with your team after bagging robot or does it go with the robot. I feel that it goes, but I want to know or if there is some advice that anyone knows with this topic in any way.
Thank you in advanced!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 17-02-2012, 21:14
EricH EricH is online now
Re: STOP Day and electronics
You have 30 lb of fabricated items (not counting the Operator Console). This could include your electronics, if you so desired.
Unread 17-02-2012, 21:17
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
AKA: Clint Ott
FRC #1619
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
If I am understanding the rule correctly, as long as you don't connect all your electronics together before you get to the event, everything (DSC, cRio, speed controllers,relays, and pretty much all other electronics except wire) would be COTS and would not count toward your 30 lb withholding allowance. Is this correct?
Unread 17-02-2012, 21:23
Student
AKA: Marco Schoener
My issue is not holding weight but rather if I can keep the electronics until competition. It is a long shot, but it would be nice to know.
Team 1369
Senior
Head Electrician
Unread 17-02-2012, 21:27
Let me go over this again:
If it's a fabricated item, you can keep it (provided that you don't have more than 30 lbs worth). If it's COTS, weight is unlimited.
It doesn't matter whether or not it's electronics. It matters that it's under the allowed weight.
Unread 17-02-2012, 21:32
Student
AKA: Marco Schoener
Well, I know that my electronics board is less than 30 lbs but for one thing,
What does COTS stand for and what does it mean?
Team 1369
Senior
Head Electrician
Unread 17-02-2012, 21:41
dudefise dudefise is offline
FRC #2637 (Panthers)
dudefise is an unknown quantity at this point
COTS means Commercial Off The Shelf - it means that the item is not custom made or modified, and commercially available. The biggest impact for your team is that it doesn't count toward the 30lb withholding allowance.
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
Unread 17-02-2012, 21:44
nitneylion452's Avatar
AKA: Joe Lee
<R22>
A Commercial, Off-The-Shelf (COTS) item is defined as a part in its unaltered, unmodified state. A COTS item is a standard (i.e. not custom order) part that is or at one time been commonly available from a Vendor. Once a COTS item is modified in any way, it becomes a Fabricated Item.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 18-02-2012, 00:15
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
to put it another way: a electrical component(victor,jag, sidecar) is a COTS item, but if its put together on an electronics board it is not.
so unless you plan on building your electronics board from raw materials and COTS items it will count towards your 30 pounds of withholding allowance.
Expect the best, Prepare for the worst
Unread 18-02-2012, 00:19
Student
AKA: Marco Schoener
So in other words, my electronics board on a rectangular plastic honeycomb structure with electronics from the KoP is not required to be bagged and shipped away or has to BE shipped under the 30 lbs of withhold.
PS I have o problem with the weight, I just want my electronics to stay behind. So is that what you are saying or does it have to go "bye-bye"?
Team 1369
Senior
Head Electrician
Unread 18-02-2012, 01:46
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Marco, please take the time to read the rules thoroughly. This is all spelled out.
If your electronics are mounted to anything or wired in any way, they are no longer "COTS" items. Therefore, they count against the total 30 pounds of fabricated components you are allowed to carry into your first competition.
If they are completely unmounted and unwired, then they are COTS items and do NOT count against the 30 pounds of fabricated material you are allowed to bring to the competition.
You can bring unlimited COTS items to the competitions.
Unread 18-02-2012, 01:59
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Pit space is limited, and I'm not sure about pit-based vendors, so ..........
If you wanted (and were extremely bold) you could theoretically bring all COTS parts with you and spend Thursday building a robot, thereby condensing 6 weeks into 6 hours. Think of all the ideas you'd see in the rest of the pit area.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 19-02-2012, 10:32
philso philso is offline
FRC #2587
"you could theoretically bring all COTS parts with you and spend Thursday building a robot, thereby condensing 6 weeks into 6 hours"
And you would not have to stay up late.
Unread 19-02-2012, 13:16
DonRotolo's Avatar
Back to humble
FRC #0832
It seems he is not even reading these posts.
Unread 19-02-2012, 16:50
Student
AKA: Marco Schoener
Don't worry, my mentor xplained it to me after I read it. I know what to do now
Thank you all again for your help!
Happy Competitions!
Team 1369
Senior
Head Electrician
