Go to Post The only thing "an eye for an eye" has ever settled is two eyeless people. - Cory [more]
Unread 18-02-2012, 00:32
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
PDB 24V keeps dying
The 24V ports on our PDB keep dying. The green LED stops lighting up after seconds of running our robot. So far we have 3 broken power distribution boards.... An ideas why?
Unread 18-02-2012, 00:35
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Re: PDB 24V keeps dying
Do you drill over your robot causing them to short out often?
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 18-02-2012, 00:36
jsasaki's Avatar
AKA: Jun Sasaki
nope. This is our third PDB and I just changed it 10 min. ago. drove for about a minute and it stopped
Unread 18-02-2012, 00:40
AKA: Garty
Is your Crio electronically isolated from your frame?
- Dr. Seuss
Unread 18-02-2012, 00:43
jsasaki's Avatar
AKA: Jun Sasaki
the whole electronics board is on lexan.
Unread 18-02-2012, 00:46
AKA: Garty
Yes but lexan can still carry a current for approx. 4-6in. When mounted directly to the frame.
- Dr. Seuss
Unread 18-02-2012, 00:47
jsasaki's Avatar
AKA: Jun Sasaki
what would you suggest for me to do ?
Unread 18-02-2012, 00:49
AKA: Garty
When you touch the robot do you might get shocked but when you touch say a bolt on your lexan board do you get shocked? If so you need to isolate your board.
- Dr. Seuss
Unread 18-02-2012, 00:55
jsasaki's Avatar
AKA: Jun Sasaki
heres a picture
Unread 18-02-2012, 00:56
jsasaki's Avatar
AKA: Jun Sasaki
nope not getting shocked.
Unread 18-02-2012, 01:33
Garten, I'm very confused by several of your responses in this thread. Do you have data to support your claims that Lexan can conduct electricity 4-6 inches and that the voltages on the robot are sufficient to cause noticeable electric shock?
Jsasaki, verify frame isolation with a meter. Then, check the insulation on the wires coming off the right hand side 40A breakers - you may be shorting there.
Unread 18-02-2012, 01:36
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
It would be nice to see the other end of the four pin connecter.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 18-02-2012, 01:40
AKA: Pat Miller
Also, those wires touching the Crio from the jag in the upper right corner at touch the Crio and those are getting power.
Unread 18-02-2012, 01:43
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Looks to me like the wire on the 5 volt camera plug is a little long.. Either that, or it's something blocking my view..
I'm right 90% of the time, so why worry about the other 3%?
Unread 18-02-2012, 01:45
AKA: Pat Miller
Yea I saw that too.
