Go to Post Perhaps we should just have signs put up that say "Please remove your head and tail before entering". - Molten [more]
Unread 18-02-2012, 00:19
blackrocks0 blackrocks0 is offline
AKA: Chaitanya Chittineni
FRC #2264 (Inceptus)
blackrocks0 is an unknown quantity at this point
Set screw problems
Our team is using chain for our bridge mechanism, and both of the sprockets that we are using have been having set screw problems. I have had to replace 3 set screws (they get stripped),while taking the sprocket on and off their about 7 times. We have drilled into the shafts (putting a dent in them) for the screw to sit in, but one of them still slipped out. What should i do?
Unread 18-02-2012, 00:23
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Re: Set screw problems
Can you possibly key the shaft at sprocket?
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 18-02-2012, 00:25
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Frankly, you shouldn't use set screws. You should look into getting keyed shaft and keyed sprockets so you don't have to worry about this anymore.
That said, if you absolutely can't get keyed stuff in time, try using Dog Point set screws into an actual hole drilled partly into the shaft instead of just a depression.
Andrew Lawrence
Posts: n/a
Well it looks like you're * takes off glasses * screwed!
Maybe adding loctite, or another adhesive to the screw? Does it work on other sprockets of the same type? I agree with Garten; Cutting it into a key will be really good, though since bag and tag is in about 3 days, you may want to do the quickest thing possible.
Unread 18-02-2012, 00:28
We have a mini-regional tomorrow, and i know they have a metal shop there, so maybe i could use the current shaft and make my own key slot.
Unread 18-02-2012, 00:32
AKA: Garty
We had this same problem with our 4 wheel shooter with 2 set screws now we have 6 set screws with 2 that are pushing down the key. It works very well. Yes it is overkill but anything can happen during a match
- Dr. Seuss
Unread 18-02-2012, 01:07
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
If you post a picture of the setup with sizes I could offer some better ideas but here are some options:
-Fast and dirty keyway: Use a dremel to cut a keyway into the shaft, then take a hacksaw, remove the blade, insert into bore, reinstall blade on saw, clamp hub in vice, "cut" keyway into bore with hacksaw. It will take some time and lots of trial fitting before you get it right. Don't force the keyway in but rather keep trimming material until it fits well. Use a set screw to press down on top of the keyway.
-Roll pins: Drill a small hole right through the hub and shaft and hammer in a roll pin AKA spring pin.
-Replace the set screw with a grade 8 bolt sharpened to a point, mill or file a good flat spot on the shaft and have at it with lots of locktite
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 18-02-2012, 08:42
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
You can also try to use two setscrews in the same hole. If you have .25" hub thickness use two .12" long set screws. Drive the first one in hard and drive the second setscrew into the back of the first one. A little blue Loctite on the second setscrew will help as well! Good Luck!
