Go to Post FIRST is definitely worth any amount of money any company gives. FIRST really puts on good events for us, and I can see where the money is going. - RBrandy [more]
Unread 18-02-2012, 02:51
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Re: PDB 24V keeps dying
more pictures
ID:	11964  Click image for larger version
ID:	11965  Click image for larger version
ID:	11966  Click image for larger version
Unread 18-02-2012, 08:42
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
In the 24v connector on the PDB, there are four wires connected. Only two should be connected. I see that there are only two wires on the CRIO end. Where are the other two going? It looks like it might be the sidecar. The sidecar should be fed by 12v on a dedicated 20A breaker.
Unread 18-02-2012, 08:45
I just looked again and it looks like the second set of wires is going to your analog breakout. That should also be powered by a dedicated 12V 20A breaker.
Unread 18-02-2012, 09:21
The second set of 24v wires feeds the solenoid breakout (properly).
I'd suggest a systematic step-by-step isolation of the problem.
If it's repeatable in a timely manner.
Example given:
  1. pull all the power breakers
  2. pull the camera and radio power
  3. pull the 24v connector
  • Turn the system on, see if the 24v power light goes out
  • if not:
  1. Add in the power breakers
  • if yes, further isolate the offending breaker
  • if not:
  1. Add the camera and radio
  • if yes, further isolate which power causes the problem
  • if not:
  1. pull the two remaining cRIO modules
  2. pull the solenoid power separately from the Breakout
  3. Add the 24v power back for just the cRIO chassis
  • if yes, probably remove the cRIO and do an internal cleaning, per NI directions. Retest.
  • if still yes, pull the second set of 24v wires from the connector and retest.
  • Check the module pins as well
  • if not:
  1. Add the Digital module
  • if yes, test in the alternate digital module slot, as well to see if the problem follows the module.
  • if not:
  1. Add the unpowered solenoid module
  • if not:
  1. Add the 24v solenoid Breakout power
  • if not: (the gremlins have won)
