Go to Post Maybe if we get lucky [the GDC] will just say chute door. - IronicDeadBird [more]
Unread 18-02-2012, 01:15
Lawlhwut Lawlhwut is offline
None #2853
Lawlhwut is an unknown quantity at this point
Encoder not working
The E4P encoder is not working on our robot right now. We plugged it into the digital side card digital I/O, 3 wire connection in 3, 1 wire (middle only) connection to 4. And in the code we declared it encoder(3,4), encoder.Start(); encoder.SetDistancePerPulse(####); and DriverStationLCD *screen = DriverStationLCD::GetInstance(); screen->PrintfLine(DriverStationLCD::kUser_Line1,"RPM: %f",encoder.GetRate());
Why isn't it working?
Unread 18-02-2012, 01:17
None #2853
Re: Encoder not working
Channel A = channel 1 signal, Channel B = channel 2 power, Grnd is -, power is power. I'm certain that the wiring is correct.
Unread 18-02-2012, 02:55
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
I hope you meant Channel B = channel 2 signal.
Unread 19-02-2012, 09:01
...3 wire connection in 3, 1 wire (middle only) connection to 4...
It isn't working because you have the B channel connected to a 5 volt power pin, not to digital input signal pin. Move it from the middle pin to the pin farthest from the edge of the Digital Sidecar.
