Go to Post Bomb squad, that grabber was the coolest way to grab a tetrahedral object in the history of grabbing tetrahedral objects. - IronVulture [more]
Unread 18-02-2012, 02:01
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
WHAT LUBE
What lube do FIRST TEAMS use on bearings?
We have bearings in the shooter high RPM's what lube?
The bearings supporting wheels what lube?
FIRST 4-H TEAM 4061
Rookie question
Unread 18-02-2012, 02:14
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: WHAT LUBE
What kind of bearings?
Are they open-race ball bearings (i.e. you can see the balls inside)? Or are they sealed/shielded ball bearings?
Alternatively, are they roller bearings? Bushings? Something else?
Unread 18-02-2012, 02:35
AKA: Dave Tharp
Re: WHAT LUBE
Open Ball Bearing.
Unread 18-02-2012, 02:52
Chris is me's Avatar
AKA: Pinecone
Re: WHAT LUBE
I have never lubed a ball bearing in FIRST, we've only bought sealed bearings and it's never been a concern.
That said, I tinkered with skateboards and scooters for years. I'd take old bearings, crappy bearings, brand name bearings, and all the rest and try to make them spin as efficiently as I could as long as I could. Stuffed anything from lithium grease to WD-40 in them (both terrible). The best product by far to grease a set of bearings was Bones Speed Cream. Any skateshop that stocks Bones bearings will have it. If not, it's easy to find on Amazon.
I could post an explanation of how I cleaned out and reworked a set of bearings, but I don't know for sure how much my answer would apply to an open bearing on a FIRST robot instead of a rubber sealed bearing on an outdoor recreational scooter / skateboard a few inches from ground and debris.
Unread 18-02-2012, 07:30
Michael Blake's Avatar
Michael Blake Michael Blake is offline
Head Coach
VRC #15842 (Texas Titans)
Michael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond reputeMichael Blake has a reputation beyond repute
Re: WHAT LUBE
FIRST 4-H TEAM 4061
Rookie question
We're using high-speed (30k rpm, I believe) sealed bearings in our shooter, so they're lubricated at manufacture... www.mcmaster.com to purchase
We're using Red-n-Tacky on gear boxes, etc...
"Retired Insurance Guy"
Link to me on this new fangled-thingy called The Linkedin and help make me popular, or at least appear to be... ;-)
https://www.linkedin.com/in/wmichael...ve_tab_profile
- President / Founder - San Antonio Competition Robotics Alliance - SACRA 501(c)(3) nonprofit (2012-present)
- Executive Director - Sports-Competition Robotics of Texas Excellence - SCRATE (2016-present)
- Former-Head Coach / Founder - FRC 3481 - Bronc Botz (2011-2016) // C++ Beta Test Team (2012 to 2016)
- Former-Lead Coach (2013-2016) Former-Head Coach (2009-2012) / Co-Founder - FTC 4008 - Bronc Botz (2009-2016) and FTC 4602 - Bronc Botz (2011-2016) and FTC 6976 - Bronc Botz-Nano for middle-schoolers (2013-2016)
- Co-Founder w/Matt Blake - VEX VRC 3481z - Wonder Botz (2011) [for Physically or Mentally Challenged Teens] (2011-2012)
Unread 18-02-2012, 07:58
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: WHAT LUBE
FIRST 4-H TEAM 4061
Rookie question
If the bearings are new then they typically do not need lube. If you are adamant that you need to lube them then I'd suggest something mild like white lithium grease, but I highly suggest not lubing them. I also suggest that you put something over the open bearings so that you don't get any swarf in them.
You should lube your gearboxes, especially if they are new (as they usually come unlubed). Here I also recommend white lithium grease, then run them 1/2 hour in each direction, clean them, reassemble and regrease.
Good luck from 1 FIRST 4-H team to another.
___________________
- Tennyson, Ulysses
Unread 18-02-2012, 09:15
ThaineP
Posts: n/a
Re: WHAT LUBE
We used white lithium on ours, and we also put some JD-80 in them, too.
Unread 18-02-2012, 09:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: WHAT LUBE
I doubt it matters too much what you use. A drop of oil, or small amount of of the grease that came in the kit for the transmissions should work.
