Go to Post Stupid rules are still rules. They're not meant to be broken, they're meant to be changed. - Alan Anderson [more]
Unread 17-02-2012, 17:15
nubie nubie is offline
FRC #2734
nubie is an unknown quantity at this point
Can't read joystick values in Java
Our team is trying to implement a simple mecanum drive in Java, but whenever we try to set a motor speed based on a joystick value, the motor simply does nothing. No error is thrown, but it does not spin.
We are extending the SimpleRobot class. We are initializing the joysticks with:
private Joystick leftStick;
public RobotTemplate() {
leftStick = new Joystick(1);
and then later on...
drivetrain.tankDrive(leftStick, rightStick);
//or
leftMotor.set(leftStick.getX());
We just switched from C++ to Java and we were able to use the joysticks fine in our C++ program, so we don't think it's a control system issue.
Any help would be greatly appreciated! Thanks.
Unread 17-02-2012, 17:23
compboy07's Avatar
compboy07 compboy07 is offline
AKA: Jake M.
FRC #2449 (Out of Orbit)
Team Role: Electrical
compboy07 is on a distinguished road
Re: Can't read joystick values in Java
The getX() method is for the kinectStick. Use getRawAxis(int axis) or getAxis(Joystick.AxisType.kX);
Unread 17-02-2012, 17:51
FRC #2734
Thank you for your fast reply. I tried switching to using the getRawAxis method, but it still does the same thing. I try:
// I also try 1-6 instead of 0
leftMotor.set(leftDriveStick.getRawAxis(0));
When I put in 3, the motor drives at full speed, but for everything else it does not drive at all. In either case, I can't control them with the joysticks. Am I missing something else?
Unread 17-02-2012, 19:10
compboy07's Avatar
AKA: Jake M.
Try two things: firstly, output your values using the LCD display class; it helps a ton. Also, try the getAxis, as it has an enum instead of the index. Instead of some arbitrary number as an argument, it uses Joystick.AxisType.kX
Unread 18-02-2012, 13:11
FRC #2734
I managed to find the default code project that was missing from the libraries on a different thread, and when I ran that, it worked. I still do not know what the root issue is but maybe I will be able to determine it in the future.
Thank you for your help.
Unread 18-02-2012, 18:14
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
No, getX() is inherited in both Joystick and kinectStick from GenericHID.
Look in the libraries at Joystick.java and you'll find
     * Get the X value of the joystick.
     * This depends on the mapping of the joystick connected to the current port.
     * @param hand Unused
     * @return The X value of the joystick.
    public double getX(Hand hand) {
        return getRawAxis(m_axes[AxisType.kX.value]);
     * Get the Y value of the joystick.
     * @return The Y value of the joystick.
    public double getY(Hand hand) {
        return getRawAxis(m_axes[AxisType.kY.value]);
TL;DR getX() works for joysticks, not just kinectSticks.
