Go to Post Admitted to MIT '14. FIRST is good stuff. - sparrowkc [more]
Unread 18-02-2012, 14:35
Redstone's Avatar
Redstone Redstone is offline
Me gusta java
AKA: Ben Beals
FRC #4043 (Nerd Herd)
Redstone is an unknown quantity at this point
Robot Control Touchy
Is there a way to make the robot start up more gradually in tankdrive and in arcadedrive? Right now i am just using the RobotDrive class to control our Sim motors.
if(driveMode==0){
drive.tankDrive(rightstick, leftstick);
if(driveMode==1){
drive.arcadeDrive(rightstick);
Unread 18-02-2012, 14:39
Re: Robot Control Touchy
Joystick sensitivity:
http://www.chiefdelphi.com/media/papers/2421
Slew rate limit:
http://www.chiefdelphi.com/forums/sh...7&postcount=30
Unread 18-02-2012, 16:23
Intel i7 Intel i7 is offline
FRC #3540 (Wildcat Robotics)
Team Role: Driver
Intel i7 is an unknown quantity at this point
Use Squared inputs
drive.arcadeDrive(speed, rotate, true);
Driver
Programmer
Webcoder/Designer
http://www.chiefdelphi.com/forums/showthread.php?t=102329
Making our own custom dashboard system/framework!
Unread 18-02-2012, 17:11
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Write your own filter into the Jaguar class in the libraries. I personally don't like the squared inputs method because it makes handling at higher speeds wierd.
