Go to Post ...sitting immediately behind Chief Delphi is a bad idea. I like the team and all, but they've given me a massive headache...They've got too much spirit. - IMDWalrus [more]
Unread 18-02-2012, 15:06
kamikazejoshua kamikazejoshua is offline
FRC #3793
kamikazejoshua is an unknown quantity at this point
banebot smoke
We are using a banebot 550 in a Cimulator. This is driving two of our wheels for the shooter. After a couple of minutes of running, there was a fair amount of smoke and we noticed the white plastic blade that cools the motor was melting. We have a spacer between the cimulator and the motor to allow air to enter through the front of the motor. Any ideas?
Unread 18-02-2012, 15:39
J_Miles's Avatar
J_Miles J_Miles is offline
FiM Referee
AKA: Jared Miles
no team (EngiNERDs)
J_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to behold
Re: banebot smoke
My guess is that your spacer still isn't allowing enough airflow. You might do well to look into machining grooves for ventilation into the CIM-U-Lator plates. There's a thread addressing this. We've posted CAD drawings of our modifications.
http://www.chiefdelphi.com/forums/sh...ight=cimulator
I can't think of any other reason, unless maybe your motors are opposing each other, although I'd think that if that were the case it would have been caught ealier.
Unread 18-02-2012, 16:00
Dan-o's Avatar
Dan-o Dan-o is offline
Strategist
AKA: Brandon Rudy
FRC #1319 (Flash)
Dan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to behold
Re: banebot smoke
The quickest way to generate heat on those motors is to run them at a stall. Are you using the motors to hold an arm steady while a force is applied? If so, you are stalling the motors.
If your motors are spinning and are still melting, I would guess air flow would be your issue. Hope this helps!
'03 - FRC 365 - Driver
'04 - FRC 1370 - Mentor
'05 - FRC 1493 - Mentor
'09-'11 - FRC 2975 - Mentor
'12-'13 - FRC 4029 - Mentor
'15 - FRC 1319 - Mentor
'07-'10 - Judge
Unread 18-02-2012, 16:22
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: banebot smoke
We smoked a 775 with an over aggressive PID. It was applying alternating large plus and minus motor sets. It didn't take long.
Unread 18-02-2012, 17:13
Re: banebot smoke
What is the total gear ratio from the 550 to the wheels?
What voltage are you running the motor at, and what is the speed of your wheel at that voltage?
Unread 18-02-2012, 17:25
FRC #3793
Re: banebot smoke
Well, this happens when the motors are running full speed. We don't need them running full speed, only like 1/4. No problem with the temperature at all at that point.
