#31
Re: How to get maximum output from a Jag?
Ether, there is a field in the BDC COMM software called ramp. If the joystick limit is manipulated is it truly adjusting the Jags ramp or is it manipulating the operators input ? seems like two different functions. Is there code examples where we can change the ramp in java?
secondly, are you saying we can change the ramp in CAN bus, but not directly in Java through PWM? thanks greatly for the insight and help. |
#32
You cannot change the ramp dynamically through PWM, in any programming language. Really, though, the ramp isn't the problem.
#33
You can accomplish much the same thing by limiting operator commands (joystick commands), or by limiting vehicle commands derived from the operator commands. This can be done in your software. Quote:
Or, that code can instead be used further downstream in your code, in order to limit the slew rate of specific vehicle behaviors. For example, consider a skid-steer vehicle with a tank-drive user interface. Process the joystick values into forward/reverse and rotate commands, and then apply the slew rate limiter to the forward/reverse only, then process the vehicle commands into motor commands. That will limit your forward/reverse acceleration but not your rotational acceleration. Having said all that, I do not think ramp rate is your problem. |
#34
Well then what do you think the problem is? I have provided as much information as I can think of, and if more is needed I will gladly provide it.
thanks for all the fish. |
#35
You are geared way too fast. It's like trying to drive 5 mph in high gear up a San Francisco hill.
I think you should gear down for more torque / less current. Last edited by Ether : 02-18-2012 at 07:10 PM. |
