Go to Post Seriously! I expect to follow what I understand to be the intent of (allow teams more time to work with their control systems) and just look out for anyone trying to bring in greater than half a robot. Or a kitchen sink. - petek [more]
Unread 02-18-2012, 05:47 PM
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Changing parameters on the fly?
Does anyone know a slick way of changing some parameters on the fly. My wife is going to attempt to tune our PID routines we have setup with crumby default values; and I want to avoid modifying a #define in code and redeploying 80 times in a day.
I've thought about attempting fopen or something like that, but that still requires me to filezilla something down there ( or SSH/terminal somehow into the robot)
If the fopen is on the right track, I'm not quite sure how I go about cracking into the robot, so a link to a guide or some instructions for that would be awesome.
Are there any sneaky methods that we could use from the driver station maybe?
Thanks in advance!
Unread 02-18-2012, 05:55 PM
Re: Changing parameters on the fly?
Thanks in advance!
You could program some joystick buttons to bump the gains up and down.
Crude, but simple and effective.
Each time you bump a button, display the actual value on your driver station so you know where you're at.
Unread 02-18-2012, 06:23 PM
Programming Mentor
AKA: Joe S
Thanks, for the idea; however over dinner I realized what I think I should do is simply debug the robot, and set watches on P,I,D temp values that get loaded each time the PID starts, and set a breakpoint, so I can modify the values from the debugger and resume.
answered my own question.
Unread 02-18-2012, 10:00 PM
agartner01 agartner01 is offline
Captain + Control Sys & Design
FRC #4174
agartner01 is an unknown quantity at this point
Yeah I've been in the same situation, and idealy I'd like to use the smart dashboard to set the values like:
examplemotor->Set(SmartDashboard::GetInstance()->GetDouble("examplekeyname");
But I could never get it to work at all.
Unread 02-20-2012, 01:02 AM
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Alright folks,
I've got answers....
Indeed - we agree that SmartDashboard::GetInstance()->GetDouble("name") does not work...however, we did find that GetString() **DOES** work. So, here's an iterative solution...
1) You **MUST** use the smartdashboard app on a separate computer due to the fact that hitting ENTER will disable the robot.
2) You must retrieve your "double values" as strings and then convert them to double/float values... see below...
3) When in operation, you simply tune your PID values by entering a new value into one of the boxes and hitting ENTER (on the 2nd laptop....see #1) and the new value will be put into the PIDController immediately so you can see the difference. When you're happy with the results, record your P,I, and D and put those into your real code. Tada.
Bob...
PIDController pid(0.00, 0.00, 0.00, &encoder, &motor);
SmartDashboard* smarty=SmartDashboard::GetInstance();
// Initially gotta put some value in order to get SmartDashboard
// to create a textbox for the value...
// Simply calling GetString() will not produce a box...
smarty->PutString("P-value", "0.0");
smarty->PutString("D-value", "0.0");
std::string tempstring;
float p, i, d;
// Initialize the pid...these values I cannot tell you ....
// They depend on your situation
pid.SetInputRange(.....);
pid.SetOutputRange(.....);
pid.SetSetpoint(.....);
pid.Enable();
while (IsOperatorControl())
  tempstring = smarty->GetString("P-value");
  sscanf(tempstring.c_str(), "%f", &p);
  tempstring = smarty->GetString("I-value");
  sscanf(tempstring.c_str(), "%f", &i);
  tempstring = smarty->GetString("D-value");
  sscanf(tempstring.c_str(), "%f", &d);
  pid.SetPID(p, i, d);
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 02-20-2012, 01:18 AM
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
The shell provided for the operating system is really a C interpreter. So you can define a global in your code then simply change its value from the command line.
in your C++ code:
extern "C" { float iMyPidGain; }
then from the VxWorks shell:
% iMyPidGain = 0.001
Unread 02-20-2012, 01:30 AM
Da' Mentor Man
FRC #1967
Keith,
Are you talking about the terminal console via the VxWorks menu (ie. Netconsole output) ??
I've never heard of this...can you point to some documentation on it?
bob
Unread 02-20-2012, 01:55 AM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Originally Posted by bob.wolff68 View Post
Keith,
bob
Yep, wtx console and host shell are both C interpreters. I never use netconsole but I assume it is also. If netconsole is the resident shell accessed via telnet, it definitely is a C interpreter also.
Help->Help Contents->Wind River Documentation->Guides->Host Tools->Wind River Workbench Host Shell Users Guide->Part 1->Using C Interpreter with VxWorks 6.X
Unread 02-20-2012, 02:03 AM
Da' Mentor Man
FRC #1967
This is really big news that I believe VERY few people know of...if I have 'external' access (on the fly) to my program's variables in an interpretive way, well...the possibilities are HUGE.
I'll be trying this with my programmers tomorrow for sure!
bob - Team 1967 Mentor - The Janksters
Unread 02-20-2012, 10:00 AM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
This feature is one of the most productive things about Wind River's setup. Remember that it is 'C' interpreter, not C++. To get your symbols into the symbol table (and thus accessible) in a usable format (not mangled by the C++ compiler), be sure to put them inside a extern "C" clause.
We use this all the time: to turn on/off the collection of data, play with operating params (like PID constants), enable/disable features while debugging etc. It definitely works!
Good luck!
Unread 02-20-2012, 10:16 AM
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
I personally use LV, so this problem is trivial for us, but would it be possible to have a CSV file stored on the robot that it reads from? So that if you modify the values, it's behavior will change?
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 02-20-2012, 04:30 PM
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Can you access members of a structure? For example:
in your C++ code:
extern "C" {
    typedef struct _PIDConst
        float Kp;
        float Ki;
        float Kd;
    } PIDConst;
     PIDConst iMyPidGain;
% iMyPidGain.Kp = 0.001
Unread 02-28-2012, 11:33 AM
mbram mbram is offline
FRC #3502
mbram is an unknown quantity at this point
Is there any other way to do this without having to have a second computer? It would not be ideal to have to laptops running at the operator's console...
Unread 03-01-2012, 06:14 PM
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
It is possible to save data to a text file on the cRIO,
and to read it back. Team 1425 has done this in the past.
Having a robot ability to update tunable parameters without firing
up WindRiver workbench is a great time saver.
This works wonders when you need to calibrate some component that is
likely to get adjusted during normal maintenance and repair during
competition.
I'm currently trying to get the team I'm working with in MN (3765)
to recreate this.
The neat thing about creating ascii based files is that you can use external tools to view them.
Last night I was showing the team how you can use the robot's built in FTP server to look at the file system on the cRIO. We looked at the system install files and noted the changes and deletions that happen when code is deployed and undeployed from workbench. We also used the ftp server to create a team data directory on the robot as a location to create our persistent data files.
On a PC that is connected to your team's robot, you can use ftp to browse the robot's file system by opening a web browser and using the URL:
ftp://10.XX.YY.2/
10.XX.YY.2 being the standard FIRST defined IP address for your robot.
Note that the protocol part of the URL is ftp - not http like you see during
regular web browsing.
This will give you a file listing of the root of the robot file system, and you can browse down into the various sub-directories.
The web browser is a good place to start since it gives a read-only view of the file system. You want to be sure that you don't modify any of the existing files there, without fully understanding the consequences.
Unread 03-01-2012, 10:32 PM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
We ftp text files to the robot and read them all the time. Our autonomous behavior is implemented with a special script language.
HTH
