Go to Post We'll get through this as a community, this we know. - JaneYoung [more]
Unread 18-02-2012, 14:12
blakeelias's Avatar
blakeelias blakeelias is offline
2011 CT chairman's award
FRC #0694 (Stuypulse)
blakeelias is an unknown quantity at this point
<G01> Question: in contact with the key.
Rule <G01> states:
The Robot must be in contact with its Key
I'm watching Suffield Shakedown and I see a lot of robots starting out autonomous with the entire robot on the key. Why are they doing this? We were just going to put the two back wheels on the key to be as close to the baskets as possible. Is that not allowed? How come I don't see anyone else doing that?
http://blakeelias.com
Unread 18-02-2012, 14:21
Rogue Leader Rogue Leader is offline
FRC #0696 (Circuit Breakers)
Rogue Leader is an unknown quantity at this point
Re: <G01> Question: in contact with the key.
I have the perception that you only need to touch the key in order for it to comply. Maybe they just don't know you only need to touch it?
Unread 18-02-2012, 19:32
GaryVoshol's Avatar
Cogito ergo arbitro
Q&A defines contact with the key (in relation to [R28], but it would also apply to [R01]):
Q. What is the definition of "in contact with its Key"? Is it one wheel touching the edge of the key, all wheels on the key, a portion of the bumper or frame overhanging the vertical projection of the key?
FRC1051 2012-01-20
A. There is no formal definition of "contact", so the colloquial definition is valid here, "the act or state of touching" (from dictionary.com).
(since 2004)
Unread 18-02-2012, 19:59
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
I was at the Nashua NH scrimmage today (full of official FIRST people) and every robot had to start with at least one wheel on the key. That's really the only possible way to touch it, seeing as appendages aren't allowed to extend before the match begins.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 18-02-2012, 20:47
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Zip ties or other dangling items from the frame would also work.
Unread 18-02-2012, 21:09
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Are we going to see teams using ties as string was used in 2002 to get an advantage?
Unread 18-02-2012, 22:12
Djur's Avatar
WPILib
AKA: Sam Carlberg
The refs would only allow the match to start if every robot had at least one wheel on the key. I'm not sure if that was just something to do with the scrimmage, but that's what I would count on as being the minimum requirement. Dangling things might be considered a safety hazard.
Unread 18-02-2012, 22:15
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
How would they be considered a safety hazard? Additionally, if someone tried to make contact with the key with an item other than the wheel but wasn't allowed, the refs were calling it incorrectly.
Unread 18-02-2012, 22:18
Djur's Avatar
WPILib
AKA: Sam Carlberg
That may have just been the way the refs at the scrimmage were calling it and not how it'll actually be in the real competitions. The Q&A seems to have been more lenient than the refs.
Unread 18-02-2012, 22:25
The rule is in contact. It does not specify what makes the contact, or how much force is needed to make contact. Any call where a robot is making contact but is ruled not to be should be brought to the Head Ref's attention immediately.
(BTW: It's not the first time the Suffield refs have been tougher than the rules. I remember hearing that they called a penalty that wasn't a penalty from the Manual a few years back--Q&A later clarified that it wasn't a penalty).
Unread 18-02-2012, 22:29
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Is the key considered the flat surface on the carpet or is it a vertical plane that goes to infinity like the 84" reach rule like last year? And if it is an infinite vertical plane, that means you should just be able to have an part of your robot just sticking out over it to be considered safe, i.e. your bridge knocker.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 18-02-2012, 22:34
It's the HDPE plastic, as defined in Section 2.
Unread 18-02-2012, 22:37
dodar's Avatar
So the safe zone is specifically the plastic on the field or is it the plane?
Unread 18-02-2012, 22:42
Djur's Avatar
WPILib
AKA: Sam Carlberg
The key is defined as that elongated semicircle of plastic, so the former.
Unread 18-02-2012, 22:43
Originally Posted by Section 2
There is one Key for each Alliance, located in front of their opponent’s Alliance Wall. The Key is an elongated semicircle that is 101 in. wide and 48 in. deep. The flat edge of the Key is located 144 in. from the Alliance Wall and centered on the width of the Court. The Key is made of 1/8 in. thick red or blue HDPE plastic attached to the carpet via Velcro.
That's not a vertical plane definition.
