Go to Post What? No Poof balls as pillows? Phfff. Amateur. :p - artdutra04 [more]
Unread 18-02-2012, 20:09
BullBot Mentor's Avatar
BullBot Mentor BullBot Mentor is offline
FRC #4368
BullBot Mentor is an unknown quantity at this point
Runaway CIM motors
Hello,
We are a rookie team, with the CIM motors running our drive wheels. During our testing today, we ran into a problem. After moving our joystick to its maximum position, the motor stuck. We released the joystick and the motor continued at top speed. After disconnecting the PWM cable from the Jaguar, we powered the system up again and the motor continued to spin at top speed.
Every time we power up the system, the motors run at top speed.
Has anyone ran into this before?
Thanks for any feedback.
Unread 18-02-2012, 20:12
adf0221 adf0221 is offline
FRC #1517 (Lumberjacks)
adf0221 is an unknown quantity at this point
Re: Runaway CIM motors
can you post what code you are using? that could help us determine the problem!
Unread 18-02-2012, 20:29
nitneylion452's Avatar
AKA: Joe Lee
Are you using encoders?
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 18-02-2012, 21:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
If you pulled the PWM cable it it still spins at full speed your motor controller is blown. Replace it ASAP. I have encountered this issue before.
Unread 19-02-2012, 11:14
FRC #4368
I was afraid of that. We had this problem on the first 2 Jags we burned up and I had the team replace all of the wiring and it looked like it was correct. We also were concerned about metal chips in the controllers, so I've been having them vaccum continuously.
Do you know what else could cause these controller failures?
Thanks for all of your feedback, we appreciate it.
Unread 19-02-2012, 11:17
FRC #4368
Thank you for your response, we are not using encoders
Unread 19-02-2012, 11:20
FRC #4368
Thank you for your reply. Our programmer has the code, I will have her add it when we get back together this afternoon.
We disconnected the computer from the circuit to try to isolate the problem. Everything was running fine before the motor just took off and the only way to stop it was the circuit breaker. Luckily we had it up on blocks while we were working on it.
Unread 19-02-2012, 11:24
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We use Victors to run the drivetrain motors, they seem to be less likely to fail in strange ways than the Jaguars. We've never had a Victor fail on a robot, but we've had a couple Jaguars fail the one year we used them for the drive motors.
Stories like this confirm that we're probably doing the right thing....even though many teams use Jags and don't have any problems...
Unread 19-02-2012, 11:39
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I will second this, with the caveat that the black jaguars seem to be way better than the brown Jags. I don't think I've had a black Jaguar die yet *knock on wood*
Unread 19-02-2012, 12:14
FRC #4368
We will try to order another Victor and go with that. I am going to check the alignment of our drive wheels and chain to make sure we are not overloading the motor.
Thanks again.
Unread 19-02-2012, 17:57
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Just to second what's been said already: if you've pulled out the PWM cable, and the motor is still running, the problem is the speed controller. It can't be the code, it can't be the encoders*, it can't be the computer, it can't be the joystick, or anything else. If there isn't any signal going into the Jaguar, and it's still running, it's broken.
I don't know what your replacement plan is, but you probably don't want to run one side of your drivetrain with a Victor and one side with a Jaguar. They have slightly different input/output curves, so the motors will run at different speeds given the same input. It certainly won't break anything, but it will probably be harder to make your robot drive straight.
* If you're using CAN, there is a way to run the Jaguars with direct encoder feedback, which will allow the Jaguar to drive the motor without being sent a constant command. Even so, it still shouldn't run on startup.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 20-02-2012, 07:52
FRC #4368
Thank you for your input,
We did order another Victor and plan to switch our drive motors to the Vics and our arm motor with the Jag. Without a "true root cause", we loosened the drive chains slightly to relieve some load on the motor. We had averything running OK yesterday, except for 1 side down without a controller. Our student morale picked up with the successes we did see and a game plan to get our new friend rolling.
Now, if we can just keep the jags from smoking...
Unread 20-02-2012, 08:28
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Immediately check your robot for a chassis short.
Although Jaguars are a point of failure, applying 12V across drive motors will spin them, no matter where the source. Albeit unlikely, make sure that this is not the case.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 20-02-2012, 09:17
Did a limit switch jumper on the Jaguar fall out? It is possible that the Jag is trying to get back from a limit condition. Full on is not the general failure on these devices. It happens but it is vary rare. If the PWM cable is left inserted and you disable the robot, does the motor continue to spin?
Unread 20-02-2012, 10:31
FRC #4368
I did take the Jaguar apart to inspect for damage and did not see any. I did not check to see if there was a misplaced jumper. Thank you for the advice.
We did disable the robot with the PWM cable removed and when enabled again, the motor took off.
