Go to Post Life can be painfully short and you never know how things could change in an instant. It never hurts to say thank you. - Karthik [more]
Unread 18-02-2012, 12:06
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
KOP fan power?
How are the KOP fans supposed to be powered? Namely the small ones from this year's kit and last.
Where on the PDB are they supposed to be plugged in?
Unread 18-02-2012, 20:33
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
Re: KOP fan power?
They can be plug into any of the 30amp max slots. What do you play on using it for?
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 18-02-2012, 20:37
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: KOP fan power?
The smaller fans are generally used on Victors (wired to the input power side). And just personal experience, in the 7+ years I've been with 810, we've never had a reason to use the larger fans. But I know there's plenty of teams that do.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 18-02-2012, 20:46
Re: KOP fan power?
The Victor fans are equivalent, but are built into the Victor. I've only used the small fans on a drill motor, used for cooling.
Unread 18-02-2012, 20:48
AKA: Scott
Re: KOP fan power?
True, the Victor fans are a separate piece though.
Unread 18-02-2012, 21:08
Registered ConfUser
AKA: Mark McGivern
Re: KOP fan power?
We worked it out. We put the 2 small pabst fans into their own 30A slots (using 20A fuses) and just soldered the wires to be longer. Do test to be sure the fans work, as over half of ours from 2011 KOP were bad or broken.
We did not try wiring them in series or parallel.
Unread 18-02-2012, 23:51
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: KOP fan power?
Good decision. You can split a single branch, but make sure each fan has its own direct supply and ground.
