Go to Post If said device costs 10x more to manufacture than a simpler solution integrating COTS parts, and only performs 10% better, that's poor engineering. - Cory [more]
Unread 18-02-2012, 21:10
Re: Banebot P60 Help
You don't have enough torque available to the belt. That's what is probably causing the motor to bind up before you apply a little starting pull. If that's what the problem is, your pattern will probably be something like:
Full battery, fresh off the charger, it works.
After a couple minutes, it doesn't work if there's a ball in there, but runs unloaded.
A minute or two after that, it doesn't work without the pull-start.
You're probably going to want to add another 550, or upgrade to a 775 or one of the AM motors.
