Go to Post Then as soon as we get the kit loaded into the back of my truck, we ferociously rip it open screaming "How many CIMs!?" - sanddrag [more]
Unread 18-02-2012, 19:56
Ben27Lacrosse Ben27Lacrosse is offline
FRC #1296
Ben27Lacrosse can only hope to improve
How to use igus chain.
My team has a 360 degree turret on top and we ran in to a wiring problem. We can't fully turn 360 degrees so we were wondering what techniques other teams have used to accomplish a 360 degree turning turret. So far we have decided to use the igus chain from the kit of parts but have no experience with this. Any help is greatly appreciated. If you have any pictures of successfully using the igus for wiring please post them!!! Videos are great too or even a detailed description on what to do. Thanks and good luck on you're last weekend of build season!!
Unread 18-02-2012, 20:35
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: How to use igus chain.
Sounds to me like you're having an issue with the wires rotating. The IGUS "Energy Chain" is more of a linear solution (http://www.igus.com/wpck/default.asp...nr=4236&C=US&L) I don't know how well it would work in your application. Something more along the lines of a slip ring is what your looking for. Not sure if that sort of thing is legal though, you'll have to check the rules.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 18-02-2012, 20:40
Slip rings are legal (given that they are of the proper size). However, the energy chain might work if given enough extra wire.
Unread 18-02-2012, 21:44
JJackson's Avatar
JJackson JJackson is offline
FRC #0781 (Kinetic Knights)
Team Role: Driver
JJackson is an unknown quantity at this point
I know this may be a little late now but we have had a lot of luck with cable zip as cable management in the past if you cant get the igus chain to work out
http://www.leevalley.com/en/hardware...597,50658&ap=1
Unread 19-02-2012, 00:16
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
A slip ring is a beautiful solution, but our team counted out something like 27 wires, and a slip ring for that could get into the three-digit range of pricing and be difficult to find. We settled on a large excess of wire in a conduit sleeve with some piano wire, anchored just above and below the turret so it can stretch around to the motors.
Maybe a little jankity, bit it works.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 19-02-2012, 03:22
FRC #1296
I think we are going with something somewhat like this. Thanks so much for the input!
Unread 19-02-2012, 10:01
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Hey Ben - need to plan where the wires get wrapped around, make sure they don't get into the shooter etc. They need to get wrapped with something, maybe a plastic spiral wrap?
Unread 29-05-2012, 14:07
Lesley,
Those slip ring assemblies are for very small currents. Generally intended for small signals rather than for power. While we could find many in the US, I couldn't begin to point you to anywhere in China.
Unread 30-05-2012, 03:47
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Adafruit.com toroid-slip-ring-2-1-od-12-id-6-wires-max-240v-5a/
Adafruit.com slip-ring-with-flange-22mm-diameter-6-wires-max-240v-2a/
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 30-05-2012, 11:41
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Looking at the slip ring. 5A will not run your shooter motors. The slip ring center line needs to be on the turret center line. So your ball transport either needs to be not through the center liner or your slip rings needs to be of sufficient Dia to allow the balls thru it.
I have never tried it, but I would be hesitant to run any kind of digital com (encoder, canbus) thru a slip ring.
Igus does make energy chain designed for 3D movement. It is a little space intensive though.
Carefull use of wire ties & spiral wrap will allow +- 180 degree rotation fairly easily.
Unread 30-05-2012, 15:24
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
Sounds like the base of your problem is you are not wiring from the axis. IE Center of rotation
Unread 30-05-2012, 15:50
mikemat mikemat is offline
mikemat has a spectacular aura aboutmikemat has a spectacular aura aboutmikemat has a spectacular aura about
I think what he is saying is that their turret is technically capable of turning 360, but they cant without pulling on or tangling the wires. Most of the teams I looked closely at had what Ekcrbe described. You cant wire from the axis because, in most turrets, that is where the balls go.
Unread 30-05-2012, 16:06
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
We struggled a bit with our shooter trying to figure this out and ended up fastening the wire bundle at the top of the shooter hood near the center of rotation. The bundle only needs to allow for some twist at that point and you have to prevent rotation to where the ball would be shooting through the bundle-- or at least prevent shooting at that point.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 30-05-2012, 16:56
That makes more sense. I thought he was recommending you route the wires up through the axis of rotation, in the middle of the turret.
Unread 30-05-2012, 17:59
If you did it that way, then you'd also need the ball cutting mechanism and ball repair mechanism at the shooter exit point. Makes it a bit more complicated...
John Vriezen
