Go to Post Yeah, if we didn't have robots then we could concentrate on all that outreach stuff! - marshall [more]
Unread 18-02-2012, 22:33
CompSciGeek CompSciGeek is offline
FRC #0948
CompSciGeek is an unknown quantity at this point
Any ideas for what we can do?
So.. our team is in the tightest spot we've been in for years. Mechanical has STILL not finished with the robot and electrical still has to wire stuff! And theres 3 days left! Programming has not even tested one bit of our code. We don't know if anything works.
We've pretty much finished all our classes and methods.
We're already probably not going to a joint practice field, but is there something programming could be doing while waiting thats really productive besides playing Minecraft?
Unread 18-02-2012, 23:00
one4robots one4robots is offline
AKA: Vince Wagner
FRC #2530 (Inconceivable)
one4robots is on a distinguished road
Re: Any ideas for what we can do?
You can take solace in the fact that you aren't alone. Have your programmers written vision acquisition code for a camera yet?
It's Inconceivable!
2015 Wisconsin Regional Winner - Thanks 2826 and 2062!
2014 Wisconsin Regional Semi-finalist and Alliance Captain - Thanks 167 and 4296!
2014 MSHSL Finalist and Alliance Captain - Thanks 3018 and 4607!
2013 Northern Lights Gracious Professionalism Award
2012 MRI Champions - Thanks, 3883 and 3630!
2012 MSHSL State Tournament Semi-finalist
2012 10,000 Lakes Regional Finalist
2012 10,000 Lakes Regional Delphi Engineering Excellence Award
2012 Lake Superior Regional GM Industrial Design Award
2011 Minnesota Robotics Invitational (MRI) Champions - Thanks, 2052 and 2450!
2011 Inaugural Lake Superior Regional Finalist
2011 Lake Superior Regional Judges Award
Unread 19-02-2012, 00:44
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Absolutely! You can fire up the cRio without the mechanical crew being finished. Just disable all the outputs and use indicators to check your code functionality. We do it all the time.
Unread 19-02-2012, 08:58
carrillo694's Avatar
carrillo694 carrillo694 is offline
Alex Carrillo
FRC #0694 (Stuypulse)
carrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the rough
Do you have robots from years past that still have their cRIOs installed? We often test our code using old robots, by making 'debug' branches off of our code that suit themselves to the actuators of the robot on which we are testing. This often means that we need to comment out certain subsystems, functions, or inputs for a given robot. It also means that we will sometimes install sensors, such as a temporary gyro for testing our "drive straight" algorithm on an older robot.
You can also run your cRIO without it connected to any actuators as Tom Line suggested, although demonstrating that your codebase is functional on another real, breathing robot can provide a morale boost.
Unread 19-02-2012, 09:20
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
I would have your electronics members and have them make you a test board. Instead of powering motors you can use cathodes to test code.
It helped our team out a good amount in fixing issues.
Good luck,
Steve
Steve
-Programming Mentor
- Team 578 Alumni
Unread 19-02-2012, 09:47
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Just the diagnostic lights on the spikes, jags and victors will help to debug your code. You can turn pots and encoders manually and see if the inputs make sense. You can make sure you are processing data from the driver station correctly. If you have a custom dashboard, you can feed it fake data and test much of that. Much of the vision functions can get tested, our team hooked up a little servo (to an old robot) to test their tracking code (since they could not turn the turntable till yesterday).
Good luck!
