Go to Post "FIRST is not about getting as little help as possible - In fact, it's the opposite- the goal is have to make you feel obligated to thank as many people as possible for helping you in ways that you didn't really think you needed or even considered that you could use help." - boomergeek [more]
Unread 18-02-2012, 22:36
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Re: Distance from key to bridge?
Distance from center front of the key to the Coopertition bridge:
324 inches from alliance wall to center of court
-44 inches from center of court to end of bridge
-144 inches from alliance wall to front of key
136 inches (11 feet 4 inches)
Source: FIRST manual
EDIT: I'm not sure if you were talking about the end of the key closest to the bridge or to the alliance wall, so here're the calculations for the tip of the semicircle:
-44 inches from center to edge of bridge
-(144 inches from wall to closest edge of key + 48 inch depth of key)
88 inches
Hope I've helped!
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
