Go to Post one wrong move and you could end up capping one of the judges. that will pretty much ruin your chance at judges' award - Mike Ciance [more]
Unread 18-02-2012, 23:29
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Banebot P60 Help
Originally Posted by BurkeHalderman View Post
We are having problems with our elevator motor. We are using a 550 motor with a 16:1 P60 gearbox and for some reason it only spins occasionally. We are controlling it with a jaguar and whenever the operator pushes the button to activate the motor the jaguar gets signal but the motor doesn't always move. If we get it starting by pulling the belt, the motor will start working but without that it is very inconsistent. Any ideas?
Like Eric said, you don't have enough torque to move your lift. Electric motors have a "start-up current" that is higher than the normal current it draws. Since your motor is under such a high load it cannot electrically overcome the initial resistance. When you move it,physically you are physically providing the force the motor needs to startup.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
