Go to Post where theres building to do, i'll be there. - Conor Ryan [more]
Unread 18-02-2012, 17:55
M. Fine M. Fine is offline
FRC #3929 (Atomic Dragons)
Team Role: Electrical
M. Fine is an unknown quantity at this point
Digital side car signal light on but not blinking?
I have a problem.
My digital sidecar's signal light is on but not blinking. All other lights on the digital sidecar are on. I have checked the breaker on the PD, the power going to the digital sidecar, and the serial cable. None of this has helped. However, we are still able to run all the jag's and run our drive-train.
Any help would be great!
Thanks,
Max
Unread 18-02-2012, 20:11
Re: Digital side car signal light on but not blinking?
Still not having any luck with the light. The light on the DSC is solid, all functions work, driving wirelessly works, yet the light is still solid. Not sure what's up, we have tried diagnostics up to our knowledge.
Need some ideas.
Unread 18-02-2012, 20:52
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Which light are you talking about? The RSL? That should be solid while the robot is enabled (It will occasionally blink while it is enabled if network drops a packet). It should blink while the robot is disabled.
- Oliver
Unread 18-02-2012, 20:56
nitneylion452's Avatar
AKA: Joe Lee
- Oliver
It should blink slowly while disabled and during teleoperated. It should be solid during autonomous.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
No the DSC have its own three status lights. I have never actually watched the DSC status light to whether its blinking or not...
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 18-02-2012, 20:58
AKA: Oliver Graff
FRC #3780
Those should be solid. They indicated power to the DSC.
Unread 19-02-2012, 00:38
Roceres Roceres is offline
FRC #1572 (HammerHeads)
Roceres is an unknown quantity at this point
I'm having the same issue. The RSL stays solid all the time: disabled and enabled in teleop.
From the post so far, I should expect the RSL to flash while the robot is disabled and during telop?
Unread 19-02-2012, 00:41
AKA: Oliver Graff
FRC #3780
Correct, the flash should be fairly quick during Disabled, and quite slow during teleop (I thought this was just due to dropped packets since it is a pretty long time in between flashes). Does the actual RSL (From Allen Bradley stay solid?) or the light on the Digital Side Car (next to the pins for the RSL)?
Good luck,
Oliver
Unread 19-02-2012, 00:42
Neither have I, which is why diagnosing this issue has me wondering what's wrong.
To repeat, we are talking about the RSL light on the DSC itself.
Unread 19-02-2012, 00:45
The LED on the DSC next to the light is also solid, ie the RSL orange light plugged into the DSC is the same as the green LED right next to the orange light connector on the DSC. What controls this? Is there Labview code somewhere that I can't find or mistakenly disabled?
Unread 19-02-2012, 01:10
AKA: Oliver Graff
FRC #3780
I believe this is handled by something that teams shouldn't be able to modify. That said, the FRC specific things preloaded on the robot are (iirc) the FPGA image, the FRC_Network_Communications.out file, and the CAN driver (if you are using one). I believe those are the things that do not vary language to language, and I don't think the RSL control is in any of them (I suppose it could be in the Network Communications module, but I doubt it). If those statements are true, then the RSL control must be in the downloaded code, which means if the Library gets modified, the RSL control could be modified. Does someone with more experience with the inner workings of what is responsible for what have any ideas?
- Oliver
Unread 19-02-2012, 11:47
have you had any luck? Sounds like we have the same problem. No fix for us yet.
Unread 19-02-2012, 14:06
carterh062 carterh062 is offline
FRC #3929
carterh062 is an unknown quantity at this point
I'm the lead programmer on Akash and Max's team. I reimaged the whole thing for LabView and reformatted to v43 (and then back to java)--to no avail. I then disconnected the digital sidecar, and took a new one, and put our wires in there. The new digital sidecar worked. I suspect that we had a faulty dsc, but it could have been in part healed by the reimaging. SOLVED
Unread 19-02-2012, 14:09
Luckily we've got 4 DSCs, not sure what caused the problem with this DSC, but we will post up if we figure out what was wrong.
Unread 20-02-2012, 22:56
I haven't figured it out yet. We might try a new DSC. I'm guessing the bad printer cables that came with reversed wiring may have messed up the DSC RSL. I'll probably give the DSC swap a shot tomorrow. By the way, we have two CRIOs and both of them showed the same RSL behavior (same digital modules).
