Go to Post I design gears and gear boxes for a living. I am HAPPY to write a check and have a solution in mailed to me. - Joe Johnson [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 19-02-2012, 02:08
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: HELP Swerve Drive!!!!!
Originally Posted by Blondie3160 View Post
our team burnt our pot up
How did that happen? Mechanical or electrical overload? If it was hooked up to the analog breakout properly, electrical load probably would not have been an issue, but I also don't see how a mechanical failure would cause it to burn up without going wicked fast (its a technical term ).
Unread 19-02-2012, 16:28
beandip3160's Avatar
beandip3160 beandip3160 is offline
FRC #3160
beandip3160 is on a distinguished road
well actually we had it wired wrong it wasnt until yesterday that we found out that they plug into the analog breakout on the cRIO
Unread 20-02-2012, 20:21
FRC #3160
I'm using the example by team 358, and have figured out the min and max on our pot however the wheels arent doing what i want they are just spinning continuously. Would it have something to do with the gains
Unread 20-02-2012, 20:52
FRC #3160
Originally Posted by beandip3160 View Post
how do you use encoders with a PID example because I just found out that we cant use them on our bot
this statement is no longer valid as we have solved this problem
Unread 21-02-2012, 17:15
FRC #3160
The pot was mounted wrong the PID works great thanks to Ether, DominickC, and Matt Krass. Thanks everyone for all the help
