Go to Post If you don't have anything nice to say, don't say it all. I mean, I know we all get frustrated during build season, but we still need to make an effort to be polite and helpful. - Karthik [more]
Unread 18-02-2012, 17:27
Re: 3 Balls in a second and a half
Originally Posted by ratdude747 View Post
they look custom, probably lathed.
Ya think? I wonder what they cost.
Unread 18-02-2012, 17:59
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
One mighty flywheel! Under some assumptions¹, I would say the largest roller takes about 6 seconds to spin up to full speed! Am I correct in my assumptions?
¹ - Dual RS775-18 motors directly coupled to the solid aluminum roller, approximately 100 mm wide and 100 mm in diameter with an 85 mm radius, giving a moment of inertia around its rotation axis of ~1067746.85 g-mm². Negligible frictional losses.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 18-02-2012, 18:43
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
How much do each of the rollers weigh by themselves?
Jason
Unread 18-02-2012, 19:26
Pun-isher's Avatar
Pun-isher Pun-isher is offline
Gotta Go Fast
AKA: Shakeel Madhav
FRC #1759 (P.O.T.A.T.O.E.S.)
Team Role: Driver
Pun-isher is an unknown quantity at this point
Looks fairly heavy considering how high it will be mounted, but very solid shooter.
The speed may be slightly overkill, maybe 2 seconds for all three balls but that's just me.
Unread 18-02-2012, 19:33
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Originally Posted by LedLover96 View Post
Is your shooter wheel direct driven by two BB RS775s? I didn't see any gearing in the video.
It is direct driven. The reason we went with this was because we had success with a similar design in 2006.
Very close, around 7 seconds was where we thought, but while its ramping up, we have plans to occupy the time.
Slow motion video had it 1.5 secs, but its a rough estimate. Again its not a final interval we want, it was just something that happened during testing.
For those asking about the rollers, they are custom made on a lathe.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 19-02-2012, 03:39
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
so shiny i am jealous...
cole?
Unread 19-02-2012, 08:21
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Epic! Reminds me a bit of the best dumpers of '09. I definitely like the aluminium rollers; you're not losing much speed as the balls come out. As for the spacing, it certainly makes sense to slow it down when you're in the key, but if you're in some other area of the field playing against defence, make sure you have the spewing ability! Unless you're a key-shooter, that is.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 19-02-2012, 08:26
RedLeader342's Avatar
RedLeader342 RedLeader342 is offline
Fabrication/Drive Coach
AKA: Justin White
FRC #0342 (Burning Magnetos)
RedLeader342 is a jewel in the roughRedLeader342 is a jewel in the roughRedLeader342 is a jewel in the rough
this is awesome sauce..
2009-Mechanical and Scouting student,342
2010~12-Mechanical, Fabrication, Operator,342
2012~13- Fabrication Mentor,3196
2013~Present- Fabrication/Drive Coach, 342
Unread 19-02-2012, 10:16
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Originally Posted by nikeairmancurry View Post
After cutting out some weight its about 15 lbs... Yes heavy, but very effective so far...
Yikes, that is heavy. Is the robot unstable to drive or balance on the bridge?
Unread 19-02-2012, 10:29
AKA: Nicholas
FRC #0313
Nope, its reinforced very nicely...
Unread 19-02-2012, 11:01
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Not structurally unstable, but dynamically unstable. 15lbs is a lot of mass to have so far off the ground.
What speed(s) are you geared for in the drive train?
