Go to Post We don't require innovation; we simply encourage it. - Tristan Lall [more]
Unread 18-02-2012, 14:17
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Can't format cRIO v2
Hey guys-
We recently tried to format the cRIOv2 with version 43, but we always get an error.
It says "Formatting cRIO..." and stays that way for several minutes. Eventually it turns up with a timeout error, and can no longer connect to the cRIO.
We have been trying to get this to format for the past 2 hours, to no avail.
Our IP Settings are 10.17.71.5, subnet of 255.255.255.0
The wireless is disabled, and we are directly tethered to the cRIO with a crossover cable.
Should we try pressing the "reset" button on the cRIO?
Unread 19-02-2012, 09:31
Re: Can't format cRIO v2
Try adding the D-Link to the middle of your connection. Your computer's network driver might be getting mildly confused by the cRIO dropping and reestablishing the electrical connection multiple times during the process, and the router will buffer it from that.
