Go to Post Baker, Skierkeiwicz, one more word out of you two and I'll have to pull out the Clipboard of Doom :p - Jessica Boucher [more]
Unread 18-02-2012, 22:21
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Modifying the Window Motor
Is taking off the front black plastic cover around the shaft on the window motor considered modifying the motor itself?
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 18-02-2012, 22:44
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Re: Modifying the Window Motor
Yes.
Originally Posted by R49
Motors, servos, and electric solenoids used on the Robot shall not be modified in any way, except as follows:
A. The mounting brackets and/or output shaft/interface may be modified to facilitate the physical connection of the motor to the Robot and actuated part.
B. The electrical input leads may be trimmed to length as necessary.
C. The locking pins on the window motors (PN 262100-3030 and 262100-3040) may be removed.
D. The connector housings on the window motors (PN 262100-3030 and 262100-3040) may be modified to facilitate lead connections.
Originally Posted by R49 Blue box
Note that for the Window motors and the AndyMark gearmotor, the gearboxes are considered integral to the motor, thus the motor may not be used without the gearbox.
This also means that modifying the gearbox is considered modifying the motor.
Jason
Unread 18-02-2012, 22:45
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Can you clarify which window motor you are talking about? Is it the Denso motor?
I'm not familiar with a black plastic cover on the Denso motor.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 19-02-2012, 10:15
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Maybe he means the spring clip?
As far as I can tell, you can only attach wires and remove pinions from motors.
Unread 19-02-2012, 11:39
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Originally Posted by jason701802 View Post
Yes.
Look closely at the regulation referenced above. It says you CAN modify output shafts, etc. The part in the blue box says, "Note that for the Window motors and the AndyMark gearmotor, the gearboxes are considered integral to the motor, thus the motor may not be used without the gearbox", is just saying you can't separate the motor and the gearbox". So you can modify the gearbox some, you just have to be sure it remains attached to the associated motor it came with.
Unread 19-02-2012, 13:11
It is integral to the motor, meaning that the only legal modifications are the ones listed in R49, there area a number of Q&A responses that support this.
Jason
