Go to Post We use the engines of our imagination on the robot all the time. FIRST being an engine of change after all. - Mark McLeod [more]
Unread 19-02-2012, 09:37
13or13 13or13 is offline
FRC #2213
13or13 is an unknown quantity at this point
How many Window Motors its allowed to use??
Hey guys i have a question how many Window motos and banebots motor are allowed to be used on a robot
Unread 19-02-2012, 09:47
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Re: How many Window Motors its allowed to use??
R48
B. up to 4, in any combination, of the BaneBots motors provided in the KOP (acceptable part numbers are M7-RS775-12, M7-RS775-18, M5-RS550-12, M5-RS550-12-B, and M3-RS395-12),
C. up to 2 window motors (acceptable part #s are 262100-3030 and 262100-3040),
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 19-02-2012, 09:56
FRC #2213
Can we use 2 of the new window motors that we got in the KoP and use alsow 2 old Window motors or we can only use 2??
Unread 19-02-2012, 10:05
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
The rest of the rule will clarify the window motor question. You can only use two of the window motors from this year or previous years if they are the same part number ( I believe they are but I cannot confirm this). You can also use 2 old window lift, seat or wiper motors.
I. up to 2 window lift, seat, windshield wiper or door motors obtained through either the FIRST-Automotive
Recyclers Association partnership or from a prior years’ KOP.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 19-02-2012, 10:14
FRC #2213
What is the difference between window lift motors and window motors
Unread 19-02-2012, 10:26
Imaginary Friend
AKA: Kevin Li
Team Role: Student
They are physically different and have differen electrical specifications. Refer to r 44 d
for the pn
Kevin Li
596 - Sciclones
Unread 19-02-2012, 11:00
Kevin--[R44] is the wiring/circuit breaker size rule. You're still looking at [R48] (and that would be [R48-C]).
To answer the question about the window motors: You can use 4 window motors, 2 from this year's KOP and 2 from either the ARA donation or a past KOP. See the following Q&A:
Game - The Robot » Motors & Actuators » R48
Q. Per rule48 we can use: "C.up to 2 window motors ..." "I.up to 2 window lift,... from a prior years’ KOP." Does this mean we can use up to 4 window motors? 2 From this years KOP and 2 from a prior KOP(same motors)? If not, what if the part numbers are different on the previous year KOP window motor?
A. Yes.
None of this "only two if they look like this year's" business.
Unread 19-02-2012, 11:14
FRC #2213
Can i use 2 window motors from this year KOP and use also the same window motors from past year KOP that mean can i use 4 window motors??
Unread 19-02-2012, 11:18
See the Q&A I posted. I would suggest bringing it with you to competition, in case the inspectors don't think a robot with 4 "identical" (2 right, 2 left, same specs) window motors is legal.
Unread 19-02-2012, 13:12
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Eric's advice is good. One more subtle thing to worry about, though. [R48C] allows this year's window motors: a left-hand and a right-hand (not two of one or the other). [R48I] allows previous KOP window motors, or ARA-sourced window motors: handedness doesn't matter for these two since both have been supplied in the past.
So, assuming you're using 4 of the Denso window motors of the type provided this year (262100-3040 and 262100-3030), you must have both types represented.
