Go to Post Seems decretive bumpers are the new rage now. I couldn't stand making them once, never mind twice. - Gregor [more]
Unread 19-02-2012, 13:11
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Re: Modifying the Window Motor
Originally Posted by JB987 View Post
Look closely at the regulation referenced above. It says you CAN modify output shafts, etc. The part in the blue box says, "Note that for the Window motors and the AndyMark gearmotor, the gearboxes are considered integral to the motor, thus the motor may not be used without the gearbox", is just saying you can't separate the motor and the gearbox". So you can modify the gearbox some, you just have to be sure it remains attached to the associated motor it came with.
It is integral to the motor, meaning that the only legal modifications are the ones listed in R49, there area a number of Q&A responses that support this.
Jason
