Go to Post This place is much brighter than most institutions I have seen. It also seems to be lacking straight jackets which I think is a mistake for many of us. - Andrew Schreiber [more]
Unread 18-02-2012, 02:53
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Team 399: Eagle Robotics Presents: X-1
Hello All!
FIRST Team 399 is proud to present our entry into the 2012 FRC game, X-1.
X-1 represents 6 weeks of hard work, breaking barriers in terms of our traditional work flow and processes.
Unveil video
Specs:
Drive train: 2 speed drivetrain. 15 feet per second in high gear, 4 feet per second in low gear. 8 wheel drive with 4 inch wheels. Geometry allows for traversal of any obstacle in Rebound Rumble.
Conveyor belt: Polycord conveyor belt. Ground to turret in about 2 seconds.
Turret: 340 degrees of motion. Camera controlled turret angle. Closed loop positioning for other functions and safety limits. RGB light ring on camera allows for dynamic control of camera tracking range(some colors track better at certain ranges than others)
Shooter: 6" wheels powered by two FP motors and geared for 4500 RPM. can shoot from about mid field. Closed loop velocity control using constant voltage control(not percent voltage control).
"Dropper": Our bridge/bump traversal tool. Uses mechanical linkages to transfer load into structure and not actuators. Acts as a wheelie bar in the case of forward tipping.
Length: 27.5"
Width: 37.5"
Height: 54.5"
Weight 118 lbs
Thanks to our sponsors: NASA Dryden Flight Research Center, Lockheed Martin, Northrop Grumman, Boeing, JT3, ITEA, BAE Systems, JCPenney, Aerovironment, Superior Grocers, Lancaster High School, and the Antelope Valley High School district.
Also thanks to Pacific Coast Coating for giving a discount on our powdercoating and the NASA Dryden Machine shop for machining our parts!
Team 399 is both proud and honored to be a part of the East West Collaboration Project(thanks, guys!).
Team Site -- Robot Page
See you in San Diego, Utah, and Colorado!
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 18-02-2012, 03:45
Re: Team 399: Eagle Robotics Presents: X-1
It has been incredible having 399 as part of the EWCP. I sincerely hope you have gotten as much out of it as you put have into the group!
The robot turned out fantastic as expected, and seeing the development of it was pure awesome. I know our team wants to especially thank you for help and collaboration with programming.
Best of luck to 399 You guys are a wonderful team to have worked with.
Unread 18-02-2012, 09:11
Great looking robot. I'm curious if the stage spotlight messed up the tracking. The retroreflective material will return any light coming from the camera and from behind/around the camera. It looked like the spot was directly behind the robot shining on the shooting targets. Harsh. Much more difficult than anything I expect to see on a field.
Greg McKaskle
Unread 18-02-2012, 09:49
davidfv davidfv is offline
FRC #0399 (Eagle Robotics)
Team Role: Tactician
davidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant future
Greg McKaskle
It was manual aiming and shooting at our roll-out event. Still have some programming to do this weekend.
Davidfv
Mentor/Drive Coach
Unread 19-02-2012, 13:28
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
wow, that is a cool robot. Your website says you use an ultrasonic sensor for distance measurement. Could you elaborate more on its usage? Is it accurate?
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 19-02-2012, 13:35
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Glad to see that 399 has stepped their game up yet again. Hope to play with you guys at some point.
-Dustin Benedict
Unread 19-02-2012, 13:53
Jacob.B's Avatar
Jacob.B Jacob.B is offline
FRC #0068 (Truck Town Thunder)
Jacob.B has much to be proud ofJacob.B has much to be proud ofJacob.B has much to be proud ofJacob.B has much to be proud ofJacob.B has much to be proud ofJacob.B has much to be proud ofJacob.B has much to be proud ofJacob.B has much to be proud of
Great robot and colors, i'm from Truck Town Thunder and we are orange and blue, as well.
Unread 19-02-2012, 14:01
Jacob Paikoff's Avatar
Jacob Paikoff Jacob Paikoff is offline
FRC reunion tour
FRC #0079 (Krunch)
Jacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant future
Great looking robot, it looks like 399 will be a force again this year. I really, really like the dropper and I'm kinda mad I didn't think of it.
Good Luck this year.
Team 79, Krunch 2007-2010 Student
Team 2059, The Hitchhikers 2011-2014 College Mentor
Team 5402, The Iron Kings 2015 Mentor
Team 79, Krunch 2016 - Mentor
Dan-o's Avatar
Dan-o Dan-o is offline
Strategist
AKA: Brandon Rudy
FRC #1319 (Flash)
Dan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to behold
Great looking machine. You guys have a lot to be proud of. Good luck in the competition.
'03 - FRC 365 - Driver
'04 - FRC 1370 - Mentor
'05 - FRC 1493 - Mentor
'09-'11 - FRC 2975 - Mentor
'12-'13 - FRC 4029 - Mentor
'15 - FRC 1319 - Mentor
'07-'10 - Judge
Unread 19-02-2012, 15:05
Sorry about that. That was written a few weeks ago when we were playing around with the sensor. We have developed past the need for the ultrasonic sensors after developing some encoder stuff. Ultrasonic sensors are only really accurate if you are within 20 or so degrees of perpendicular to a wall or some other object being measured. It also gives weird readings when the sound hits a porous material such as the balls or bumpers.
Haha. All of our media seem to depict our purple a very dark blue.
Thanks. It seems it is our most versatile system. We've tested it to work as a bump/bridge traversal tool, a wheelie bar, and a mini hopper!
Greg McKaskle
From what I saw from the camera's live feed, the spotlight didn't have much of an effect over our RGB ring on board. We are testing software that dynamically changes the RGB's color and camera HSL thresholds based on target distance or target visibility
[FF] FIRST Pick
Unread 19-02-2012, 15:21
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
From your pictures, it looks like you are using Jaguars via CAN.
It also mentions you are using 2 FPs for your shooter, using speed control.
Are you using the built-in Speed PID function of the Jaguars?
If so, two questions for you:
1) How did you tune your Speed PID for the Jaguars? What are your PID constants?
2) How did you get 2 Jaguars to run in sync with each other without them interfering with each other? Did you split the encoder signal? Read the voltage from one Jaguar and send it to the second?
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 19-02-2012, 15:50
Thanks for noticing. Before I explain anything, I'd like to thank you for all the work and information you've posted on CAN Jags and Velocity control.
Following the advice from one of your posts, I decided to offload V PID to the cRIO. However, we are still using the encoder port of the Jag(one encoder to one jag). Unfortunately, we found major inconsistencies in the jag's velocity data(+/- 20%). As a slight workaround, we have our software calculate the derivative of jaguar.getPosition rather than letting the jag do it.
Since all of the processing is on the cRIO, it was pretty simple to sync the two motors. I simply took the output from the calculation and set it to the jaguars while using SyncGroups.
Thank you, and if you have any more questions, ask away!
[FF] FIRST Pick
Unread 19-02-2012, 16:35
AKA: Mr. Lim
Thanks for sharing the info Jeremy! I was hoping there would be a great "CAN Jaguar Velocity Control w/ 2 Motors Success Story" here. However, you wouldn't be the first team to ditch the on-board Jag PID for a more flexible software approach. I don't think you'll be the last either...
Best wishes and good luck in 2012! Hopefully we'll cross paths in St. Louis!
Unread 19-02-2012, 16:46
delsaner's Avatar
delsaner delsaner is offline
With Upmost Efficiency
AKA: Eric DelSanto
FRC #1676 (Pascack Pioneers)
delsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant future
The bridge manipulator, the elevator, the rotating shooter; all of the components seem absolutely flawless. Good luck at the competitions!!
"The creations of the hand are confined by reality. The creations of the mind know no such limits."
~MtG - Mind Unbound
Eric DelSanto
Game Announcer
H.E.R.E. Representative
Stevens Institute of Technology - Class of 2016 - BE/ME Mechanical Engineering
Concentration: Robotics, Mechatronics
[2008-2014]: FRC 1676 - The Pascack Pi-oneers
Last edited by delsaner : 19-02-2012 at 16:48. Reason: Question previously answered
Unread 19-02-2012, 21:46
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
Man that thing is amazing, i cant wait to compete against you guys in San Diego.
2014 Colorado Regional Winners (Thanks 3310 and 2543)
2013 San Diego Regional Winners (Thanks 987 and 254)
2013 San Deigo Regional Entrepreneurship Award
2012 Los Angeles Regional Semifinalists (Thanks 599, 3309)
2012 San Diego Regional Finalists (Thanks 399, 2339)
2011 Los Angeles Regional Chairman's Award
2011 BAE Regional Judges Award
