Go to Post Look, it's only August. You got approximately 6 months to enjoy your life until season starts. Enjoy it while it lasts... - Arefin Bari [more]
Unread 15-02-2012, 10:16
Gatlin18 Gatlin18 is offline
FRC #2373 (Crickets)
Gatlin18 is an unknown quantity at this point
Not showing Battery Voltage
When we turn our robot on, connect, and start to run it, it works perfectly. But, the voltage of any battery we connect stays at 0.00. No idea what is the problem. Any ideas?
Unread 15-02-2012, 10:22
Re: Not showing Battery Voltage
No idea what you've done or tried.
Did you put the battery jumper on the Analog Breakout in cRIO slot 1?
Did you power the Analog Breakout from a 12v on the Power Distribution Panel?
Unread 15-02-2012, 11:02
I had a different connector than that. I just put that one in, and I am not looking for the jumper to try it. Thanks.
Unread 15-02-2012, 20:38
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
It's most likely the jumper is not in the correct spot, or not at all. However we did have a rookie team that had the same problem even with the jumper installed, turned out to be a bent pin in the underneath the analog module on the crio. So be aware of that.
Unread 17-02-2012, 08:23
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
Yeah if that jumper is in the right place and the analog module is powered, you should be able to see the battery voltage in the driver station and the dashboard if you have that programmed in.
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 19-02-2012, 14:32
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
What do you mean Programmed in?
Unread 19-02-2012, 14:43
It's not in code that you should be modifying, IIRC. It should be a case of plug the jumper in and open the proper tab in the driver's station, and you'll see your battery voltage.
