Go to Post However, as a philosopher, while you need math, you can probably talk your way out of it. - sciguy125 [more]
Unread 18-02-2012, 12:38
team4213 team4213 is offline
FRC #4213
team4213 is an unknown quantity at this point
Power Board Placement
Hello, we have a question pertraining to rules on the mounting of the Power Distribution Board. On the 2012 FRC Inspection Checklist, it states the following:
Visibility -PD and breakers must be easily visible. <R43>
We were thinking of mounting the PD board inside a cage with the rest of our electrical components, ( see and ) will this rule change anything? Or will we have to mount it outside the box?
Unread 18-02-2012, 13:35
Becca334's Avatar
Becca334 Becca334 is offline
AKA: Rebecca
FRC #0334 (TechKnights)
Becca334 is a jewel in the roughBecca334 is a jewel in the roughBecca334 is a jewel in the roughBecca334 is a jewel in the rough
Re: Power Board Placement
Visibility means to be easily seen. Inside the cage should be fine, however make sure your breaker is OUTSIDE the cage, because that is the part that needs to be easily accessible.
Unread 19-02-2012, 00:23
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
That box looks (from just two pictures) to be a large waste of space--not to mention unnecessarily heavy--unless your design calls for it to be very exposed and unprotected.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 19-02-2012, 15:32
FRC #4213
Smile Re: Power Board Placement
Thanks, the breaker was going to be outside anyways. We were also considering putting a plexiglass cover on as opposed to the current metal one (Our jaguars and spikes are mounted to the the top of the box, though) to help visibility.
Unread 19-02-2012, 15:37
Becca334's Avatar
AKA: Rebecca
Hm, if anything I'd make the the jaguars are inside the box. You dont want anything to get in them or such because they do have a tendency to be unreliable. That is, if you're still going to keep the box.
I have lexan plastic over my victors, and while the robot was just in the shop the amount of metal sharps/anything else that got on it were shocking.
Whatever you end up doing with your electronics board, cage or not I'd highly suggest to keep the jaguars covered.
Unread 19-02-2012, 16:12
FRC #4213
Wink Re: Power Board Placement
The jags are mounted on the inside of that lid, facing the cRIO, digital sidecar and PD, so they are covered.
Unread 20-02-2012, 10:26
Team,
The visibility requirement means exactly what it says. Everything must be visible for both inspection and diagnosing. As inspectors we need to see all wire terminations and breakers, all controllers, terminations for the Crio, wireless bridge and it's regulator, and all LEDs during the power ON tests. While this box is really nice, if you can't open it easily to satisfy the visibility rules you may not pass inspection. All of these critical items make it easier for us to help you diagnose problems.
