Go to Post "It is a guaranteed fact that at least one rookie team will name their robot 'Chuck Norris'." - Tim Arnold [more]
Unread 19-02-2012, 15:40
moler moler is offline
FRC #0772
moler is an unknown quantity at this point
Can you put ducktape on wheels
Hey everyone,
is it legal to put duck tape on the wheels to make them slip a bit??
thanks
team 772
Unread 19-02-2012, 15:43
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
Re: Can you put ducktape on wheels
I believe it is legal but why don't you use the 2009 wheel that are low traction.
Unread 19-02-2012, 15:49
Legal? Yes.
Optimal? No. There's a fairly high chance of the duct tape wearing quickly, or otherwise separating from the wheel.
You could try wrapping zip ties around the rim of the wheel; this will reduce the friction in the sideways direction, but maintain front and back traction.
Unread 19-02-2012, 16:01
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Yes, but watch out for [G12]. If you damage the field (e.g. leaving smears of adhesive in the carpet) the head referee may have your robot disabled, and you'll have to correct the problem.
Unread 19-02-2012, 16:02
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
The method that Eric Suggested has been used by teams as far back as I can remember and works reasonably well and can be undone/done in a pinch.
Another, slightly more permanent method is to attach a strip of plastic to the circumference of your wheels to make them low friction. Watch what you use to attach it though, any bolt heads/rivet heads/fasteners need to either be countersunk so that they don't touch the carpet or be made from plastic if they do.
-Dustin Benedict
Unread 19-02-2012, 16:10
ZeroGAdam's Avatar
ZeroGAdam ZeroGAdam is offline
AKA: Adam
ZeroGAdam will become famous soon enoughZeroGAdam will become famous soon enough
I would be careful with using zip-ties in your wheels to solve a turning problem... I only say this because of experience... Back in 2006, my old team's (381) robot had 4 pneumatic grippy tires and turning was terrible. To compensate for this we used the zip-ties and it solved all of our problems at the NJ Regional. After that competition, we went to the Philadelphia Regional, and the inspectors deemed it illegal because they were afraid of "surface damage" to the carpet. I always wondered why this was, and when the same issue came up this year again with my current team (2180), we had to look at other methods. We're using shrink wrap around our front wheels. While it might not have as much traction, turning is a breeze...
NEFIRST Game Announcer 2015 - Present
Team History
FRC Team 190 2014 - 2015
FRC Team 2180 2010 - 2014
FRC Team 381 2002-2008
FTC Team 221 2010-present
Unread 19-02-2012, 16:20
FRC #0772
thanks everyone for your help
Unread 19-02-2012, 23:23
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
I put the duct tape on the front and back wheels today. We are using pneumatic wheels so zip ties wasn't an option of us and I really don't wanna use them
Turning is wonderful now. So far the tape seems to stick on perfectly as the outside edges are never in contact with the floor because of the tires being rounded. We will see if anything goes wrong later
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
