Go to Post Two students with no clue but enough dedication to work on something is always better than one expert who doesn't care enough not to leaveit until the last day. - Matt Krass [more]
Unread 18-02-2012, 15:42
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
swwrobotics is an unknown quantity at this point
Tank or arcade drive?
Hey everyone, just wondering, for this year's game, would it be better to have a tank drive, or arcade drive using the joysticks that came in the kit? Our team is trying to figure out which one we should control the robot with and I was thinking maybe tank drive because it might be more intuitive. Any advice?
Unread 18-02-2012, 15:54
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
Re: Tank or arcade drive?
I know our drivers use arcade drive. They feel it offers them more control.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 18-02-2012, 17:10
It's personal preference. In other words, do hatever your driver(s) want.
Unread 19-02-2012, 14:33
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
By default our bot is Tank, but I have a button to switch to Arcade if you have to reach for a different button or switch and want to continue to drive the robot at the same time.
Unread 19-02-2012, 16:12
delsaner's Avatar
delsaner delsaner is offline
With Upmost Efficiency
AKA: Eric DelSanto
FRC #1676 (Pascack Pioneers)
delsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant future
My personal preference from a performance standpoint is Tank Drive, primarily because precision of movement is allowed more in tank than arcade. I am no programmer, but I presume that Tank Drive is easier to code than arcade. We have used Tank Drive for the last few years, and we have gotten success with it.
As others have said though, it is really up to the drivers. Optimized performance and comfortable environment are generally associated with one another. Ask them and see what they would be more comfortable with.
"The creations of the hand are confined by reality. The creations of the mind know no such limits."
~MtG - Mind Unbound
Eric DelSanto
Game Announcer
H.E.R.E. Representative
Stevens Institute of Technology - Class of 2016 - BE/ME Mechanical Engineering
Concentration: Robotics, Mechatronics
[2008-2014]: FRC 1676 - The Pascack Pi-oneers
Unread 19-02-2012, 16:44
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Call me crazy, but every year I always insist my driver candidates try "Kaj Drive"
It's similar to Arcade drive, but the Y-axis and X-axis are split respectively onto the left and right thumbsticks on a Logitech Gamepad.
Left thumb controls forward and reverse.
Right thumb controls rotation.
Given how important "driving straight" is when driving up a bridge... you may want to consider this layout over tank. Tank drive is notoriously difficult for driving in straight lines.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 23-02-2012, 18:10
touchdownjesus4's Avatar
touchdownjesus4 touchdownjesus4 is offline
AKA: Tyler Vonderhaar
FRC #4028 (Eagle Robotics)
touchdownjesus4 is on a distinguished road
I was thinking about doing something like this, just have no idea how to program it. I'm programming in java and currently have it set up to do tank drive but wanted to try out this type of system. How does your team implement this?
Unread 23-02-2012, 18:43
left_wheels = (ForwardCommand + ClockwiseRotationCommand)/2
right_wheels = (ForwardCommand - ClockwiseRotationCommand)/2
ForwardCommand and ClockwiseRotationCommand are -1 to +1.
ok so the clockwise rotation command would come from the right joystick and the forward command from the left..
Would you just have the motor set at that speed given by the formula you gave?
Also, why are the values divided by 2?
Unread 23-02-2012, 19:28
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
Orginally our drivers asked for Tank. Then after driving around they wanted it switched to arcade because they felt it gave better control. So teleop driver is now arcade.
That being said, our Kinect-enabled autonomous drive is in Tank.
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 23-02-2012, 19:30
correct
left_wheels get set to (ForwardCommand + ClockwiseRotationCommand)/2
right_wheels get set to (ForwardCommand - ClockwiseRotationCommand)/2
So they stay within the range -1 to +1
Alright great, probably could have answered that last question if I actually thought about it a little more.
I'll get some code set up to test out once we get to competition, I can't wait to get more driving practice in!
One other question.. If the value is divided by two would this limit the robot to only go at half speed at any given time?
Unread 23-02-2012, 19:36
You could use the following method
public void arcadeDrive(GenericHID moveStick, final int moveAxis, GenericHID rotateStick, final int rotateAxis, boolean squaredInputs)
Set moveStick and rotateStick to your controller and moveAxis to the y axis of the left stick and rotateAxis to the x axis of the right stick.
The disadvantage of this algorithm is that when Forward Command is 1 and ClockwiseRotationCommand is 0, you only move at half speed.
I've attached a quick comparison between Ether's algorithm, the arcade drive in WPILib (Java and C++, not sure if it's different in LabVIEW), and the algorithm that we use. (We drive with tank drive in telop, but find that "arcade" is easier to program for in autonomous)
Unread 23-02-2012, 20:05
Dusk Star's Avatar
Dusk Star Dusk Star is offline
team Chief Delphi junkie
AKA: Andrew
FRC #2611 (Jacktown Vectors)
Dusk Star is an unknown quantity at this point
We called that FPS drive, as the left movement, right rotation layout was immediately familiar from Halo, BF3, CoD, etc. And we implemented it, on a controller, with something like myrobot.arcadedrive(stick1.getrawaxis(KYaxis), stick1.getrawaxis(KZaxis)); synatax is probably wrong though!
Unread 23-02-2012, 20:49
Ok I'll just use the arcade drive method, I had it in my mind that arcade drive was something different for some reason.
Unread 23-02-2012, 22:32
Thanks guys. I'm having a bad day today. Caffeine withdrawal.
http://www.chiefdelphi.com/forums/sh...2&postcount=25
