Go to Post The whole idea of a robot competition is geared around spectators. Take that away and you have a science fair. - Chris is me [more]
Unread 19-02-2012, 16:22
zrem zrem is offline
FRC #2130
zrem is an unknown quantity at this point
Lightbulb Returning battery voltage into user program
Hey is there anyway to return the battery voltage to the user program, our team was noticing that we need to aim slightly differently in order to compensate for the drop in voltage caused from running our motors. So I was hoping there was someway to return the voltage and compensate for it in order to be more accurate any help on this would be awesome.
Thanks: 2130 Alpha+
Unread 19-02-2012, 16:36
jase728 jase728 is offline
AKA: Jase728
FRC #3210 (Falcons)
jase728 is an unknown quantity at this point
Re: Returning battery voltage into user program
uhmm in Java the battery voltage can be returned as a get method in the driverstation class
"In theory there is reality, but in reality there is no theory" - Erich Keane (FRC 2010 Build Season - Team 3210)
Unread 19-02-2012, 17:15
FRC #2130
Yes however I was needing it in C... where is it under the java though? it might be under a similar file in C.
and It is thank you very much
Unread 19-02-2012, 17:45
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
http://rbmj.github.com/612-code/doc/...0cf80 30f85bf
Unread 19-02-2012, 18:12
AKA: Jase728
FRC #3210 (Falcons)
Uhmm I think in Java if you import the DriverStation class or it might be in the DriverStationLCD class
Unread 19-02-2012, 18:32
There is a method for this in the Driver Station class.
This line code should do what you want I believe:
float voltage;
voltage = DriverStation::GetInstance()->GetBatteryVoltage();
Unread 19-02-2012, 19:29
Dale(294engr]'s Avatar
Dale(294engr] Dale(294engr] is offline
Mentor/Sponsor since '98
Dale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of light
Zem.. you may wish to consider / implement encoder feedback closed loop speed control on shooter motor (PID)
to automatically compensate for battery voltage droop and dynamic IR load drops from drive motors
and apply full power after each shot to most quickly get back to regulated set speed needed for consistent shooting.
