Go to Post If they don't treat Dave nicely, he may just keep his big red ball, and not share with rest of us. - Barry Bonzack [more]
Unread 18-02-2012, 09:22
irrelevanttaco irrelevanttaco is offline
FRC #1987 (Broncobots)
Team Role: Animator
irrelevanttaco is an unknown quantity at this point
Artifacting
Besides the lack of textures in this render what should i do to fix the spottiness in the image? Besides upping the final gather, should i increase the bounces or what?
Unread 18-02-2012, 10:18
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
Re: Artifacting
Are you using Global Illumination? If so, try increasing the amount of photons you are using, or taking more photons per sample.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 18-02-2012, 11:21
Team Role: Animator
Re: Artifacting
Actually i currently have GE off. Im just using a daylight system to simulate light. Im having a terrible time fixing this. Its the only thing i have left to do.
Unread 18-02-2012, 11:38
AKA: Ryan Zoeller
Re: Artifacting
What are your final gather settings?
FRC 2169 Alumni
Unread 18-02-2012, 11:42
Team Role: Animator
Re: Artifacting
Well that render was in draft. But i usually have it up around medium. With 3 bounces. But it hardly takes any of it away.
Unread 18-02-2012, 12:39
Team Role: Animator
Re: Artifacting
Here it is rendered in medium FG. With textures
Unread 18-02-2012, 14:03
AKA: Ryan Zoeller
Re: Artifacting
It looks like you might not have enough polygons in the abduction ray? Or else that is just the artifacting itself more seriously.
FRC 2169 Alumni
Unread 19-02-2012, 15:30
playbass06 playbass06 is offline
"bass" as in the guitar, not a fish
AKA: Chris Schaaf
FRC #1986 (Team Titanium)
Team Role: Animator
playbass06 is an unknown quantity at this point
Send a message via AIM to playbass06 Send a message via Yahoo to playbass06
Re: Artifacting
Try instead, putting FG back to "Draft," (it's more of a personal preference, but it tends to give you good results in little time, good for base settings) but then go to the Render Setup window. On the Indirect Illumination tab, in the Final Gather section, there should be a parameter named, "Rays per FG point." Try increasing that (default 50, try 150-200). I'd probably not go over 300 rays with that, it gets slow.
I'm not sure how much this will improve it, but it could help. It looks more like a shadow issue in some spots, and less FG. Have you tried increasing the Soft Shadows Precision multiplier?
Unread 19-02-2012, 17:04
SCRktkt SCRktkt is offline
SCRktkt is an unknown quantity at this point
Re: Artifacting
Here are some things to do for better looking renders:
1. Increase your Final Gather accuracy; the default for draft renders is 50. In 3ds Max, this is called Rays per FG Point, and Accuracy in Maya.
2. Increase the Soft Shadows precision on your sun as the default Samples may be too low at 8.
3. Turn on your speckle reduction, or turn it up to high.
4. Increase your anti-aliasing as the default may be too low.
In my experience, speckles like you have are usually from one light source trying to do too much in a room, leaving much of the room lit by bounced light. While it is feasible to do this via brute computing force, it may be better to add other lights into the scene. Increasing the number of secondary diffuse bounces will not reduce speckles; what it does is allow the light to bounce more times off surfaces and give the scene a more luminous feel.
Depending on what is moving in your scene besides the micro-iiko on the table, you may want to consider a composite render. This will allow you to render the environment with frozen Final Gather, and then another pass with just the iiko on a matte/shadow. You could also try turning off final gather casting on the iiko, and just let him receive. Often speckles are caused by small objects casting final gather across the room on larger things. If you need help setting up composite renders or otherwise, let me know.
Adam Crespi
Autodesk Certification Evaluator
Instructor, The Art Institute of Seattle
Unread 21-02-2012, 15:56
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
Re: Artifacting
IMO, that noise will be lost in movement and in the final quicktime compression - I think it looks good
Unread 21-02-2012, 18:51
Team Role: Animator
Re: Artifacting
Ive increased the rays all the way to 1000. Still looks the same. Same with all of the other suggestions. I do only have the daylight gizmo in the scene. Im not really sure what type of light i should add to the room.
