Go to Post Smart defense doesn't even require your robot to push another. - Cory [more]
Unread 18-02-2012, 22:30
TeamUpNext3528's Avatar
TeamUpNext3528 TeamUpNext3528 is offline
FRC #3528 (Team UpNext)
Team Role: Driver
TeamUpNext3528 is an unknown quantity at this point
Bridge lower-er Motor? (HELP!)
Hey guys, David here from team 3528. Our team is having some trouble with the bridge tipper. We have been using the window motor that we got in the kit of parts for the bridge lower-er but its not strong enough to push it down.
What kind of motors do you all use? We need to be able to replace it in 2 days (bag and tag is the 21ist!!)
Unread 18-02-2012, 22:51
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Bridge lower-er Motor? (HELP!)
You have a quite a few options to work with. You can use a gear reduction out of the window motor to give it more torque and thus more force on the end of your arm.
You can combine two window motors and use a reduction as well. You could make your pusher arm as short as possible to deliver more force.
Also, the AM-0914 is about twice as powerful as the window motor.
You can use another motor like the fisher price + fisher price gearbox if it is available.
What other motors do you have available?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 18-02-2012, 23:04
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
We use the motors in the drivetrain. (video)
Unread 18-02-2012, 23:28
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Use the window motor you have and attach an angle piece that will shove the bridge down. Those locking pins can be helpful!
Expect the best, Prepare for the worst
Unread 19-02-2012, 10:13
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Also remember the 30 lb allowance to withhold fabricated parts. You have two days to design something that fits in the spot, but you can make it next week.
I recommend a Van Door motor, such as the one AndyMark has.
Unread 19-02-2012, 10:24
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
We use a window motor with an arm and a catch. The arm contacts the ramp on the catch, so that the robots forward driving motion pushes the ramp down. This is achieved by having the pivot for the arm several inches above the top of the bridge, although the drive-train has about a 5-1 mechanical disadvantage it is still more than capable of pushing the ramp down.
Unread 19-02-2012, 11:16
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Hebrew is an unknown quantity at this point
At a scrimmage yesterday the best bridge lowerers were a triangle like thing that people dropped then simply drove right up to the bridge and a pneumatic piston throwing down an arm. Our team is using the piston/arm and it is working excellent.
Unread 19-02-2012, 17:18
GDG 2337 GDG 2337 is offline
FRC #2337 (ENGINerds)
GDG 2337 has a spectacular aura aboutGDG 2337 has a spectacular aura about
FRC Team 3601 was having an issue lowering the bridge using an arm hooked to a PG71 gear motor. To help them out, the NerdWorks placed the PG71 into a Toughbox Nano. We had previously build them a custom 10mm hex adapter for use into an AM 500 hex hub. We bored and hexed broached a 19 tooth counter shaft gear to use as an input gear and paired it with a 45 tooth output gear with a 1/2 to 3/8 hex shaft adapter. It works well.
ID:	11995  Click image for larger version
ID:	11996  Click image for larger version
