Go to Post Mmmmm, First Choice day. I can already taste the latency. - ttldomination [more]
Unread 18-02-2012, 19:02
Darthjawafett Darthjawafett is offline
FRC #3059
Darthjawafett is an unknown quantity at this point
FRC Dashboard help
Okay so I modified a dashboard to contain a switch for the robot. So that when the switch is pressed it would light up on the screen. Now I have two questions.
1) Why wont the switch Run on the Dashboard VI? (It runs using the Simple Digital Output Example)
2) How do you get the Dashboard Vi to be used when the FRC PC Dashboard is opened with the Driver Station?
Thanks from Team 3059
Unread 18-02-2012, 21:27
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: FRC Dashboard help
Here's the basic rundown you'll need to do.
1. Open the switch in Begin.vi.
2. Read the switch in either Teleop, Autonimous, or Pereodic Tasks.vi, depending on when you want to gather information.
3. Flatten to String and send your switch information to the Dashboard.
4. In the Dashboard, Unflatten the data and wire the output to your boolean light. It'll light when true, or when your button is pressed.
Unread 19-02-2012, 17:34
FRC #3059
would it look like this:
