Go to Post Lawrence North has air conditioning. If it didn't, more than just balls would be sticky. - Andy Baker [more]
Unread 18-02-2012, 21:06
rivasm rivasm is offline
FRC #2556 (RadioActive Roaches)
rivasm is an unknown quantity at this point
Please Help Us with Vision Processing. Please.
My fellow programmers and I have had the most absolute hard time programming Vision Processing. We can run and detect the reflective tape based off of intensity, which is our preferred method, from the Rectangular Target Processing example code. We have successfully integrated it into our own, as well. However, we cannot get any sort of display to see that the code is working. Please, please, please, please, please help us.
Unread 18-02-2012, 22:17
Re: Please Help Us with Vision Processing. Please.
If you just want to debug and see if it is working, you can run the code using the Run button, open the VI, and turn on annotations. LV panels will slow execution speed, but they are great for debugging.
If you are talking about your deployed code and keeping it around after you know it works, look to integrate the annotations into the dashboard. Clearly you need the Target data array sent back. You can flatten the data and send it from the robot as Low or High priority data. They are basically the same.
Once you have the flattened data in the dashboard, add the data to the cluster that is extracted from the string and wire it into the annotation code.
Greg McKaskle
Unread 19-02-2012, 10:52
wildcats843 wildcats843 is offline
FRC #0843
wildcats843 is an unknown quantity at this point
https://decibel.ni.com/content/docs/DOC-20686
Unread 19-02-2012, 20:37
We are using the cRIO II. Also, we have image feed. We just want a way of indicating that our code is detecting the camera.
Unread 19-02-2012, 22:42
You can write a line to the Driver Station screen saying either "Camera Detected" or "Camera Not Detected", as applicable, using the Driver Station/Write User Message function.
