Go to Post And to think, a lot of students are planning parties and celebrations on their last day of school and you guys are recycling trash. - JaneYoung [more]
Unread 19-02-2012, 20:38
jeremy5561 jeremy5561 is offline
FRC #0919
jeremy5561 is an unknown quantity at this point
Programming Spike Relay
I tried programming the spike relay to turn an am-0914 motor today and it doesn't work. The motor doesn't turn.
I'm programming it so that when the trigger on the joystick is held down, the motor spins.
The relay is connected to Relay1 on the Digital Sidecar. The light on the relay is orange. When the trigger is held down, the light on the relay is still orange, though in labview front panel, I can see the SetRelay front panel RelayValue is set to forward. The front panel looks like this when the trigger is held down:
Am I programming something wrong?
PHOTOS BELOW!!!!:
http://coldwartimeline.tk/DSC00106.JPG
http://coldwartimeline.tk/DSC00104.JPG
There is one more picture with the relay but the guy who's supposed to send them hasn't.
Update
I Just saw the photos and noticed that thing thing is connected backwards. That's because we tried connecting that wire to every relay port in every direction. I also just noticed the light next to the relay. That's kind of comforting. Maybe the Spike is broken?
Unread 19-02-2012, 21:22
chi-town-biker chi-town-biker is offline
FRC #3135 (Robotic Colonels)
chi-town-biker is an unknown quantity at this point
Re: Programming Spike Relay
Team 358 has an excellent example of programming a spike in Labview. See http://team358.org/files/programming...2009-/LabVIEW/ I've attached the relevant section. (It's faster to copy theirs than write my own example.)
Name:	relay per 358.png
Unread 19-02-2012, 22:25
FRC #0919
I'm pretty sure thats how I programmed our relay. I used a case instead of a select and it has forward when true and off when false. I'm beginning to think its a spike problem rather than a programming problem. I'll look into it tomorrow. If anyone sees anything wrong let me know.
I will try copying that code tomorrow though I doubt it would make a difference.
Unread 19-02-2012, 23:04
Originally Posted by jeremy5561 View Post
Update
I was going to point out both the lit green LED and the apparently backwards connector, but it looks like I don't have to.
