Go to Post Once you get to college, remember that FRC is not your life anymore (or at least it doesn't have to be). Don't be afraid to try new things, and branch away from the things you swear by in high school - buildmaster5000 [more]
Unread 19-02-2012, 22:23
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Re: Overworked jaguars
Well, let's see what you think with this info:
I am programming in Java and I had the program on an axis control for testing. I recently programmed a speed buttons and will test it tomorrow. This is a SimpleRobot setup and we are not using CAN setups.
The direction is only one direction and I do not seem to understand how to answer the last two quests/thoughts, possibly due to terminology.
I have seen your single post of the rate-limit and have had programmers block on implementing that system with a single button use.
I hope I supplied enough information. If not, catch me on it and tell me what you think!
Thanks again for the help!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
