Go to Post I can attest that mentoring is probably the most important aspect of this program. - Tom Bottiglieri [more]
  #46   Spotlight this post!
Unread 05-01-2003, 09:37
Noelle Noelle is offline
#0180 (S.P.A.M.)
Noelle is on a distinguished road
Send a message via AIM to Noelle
Originally posted by Bduggan04
You're not thinking out of the box. If each contaner was stacked length to length you'd have 24.25"*#ofbinsstacked/15.75"
15.75" is the hieght of one bin in it normal orientation. 24.25" is how long it is.
With 21 stacked the actual hieght would be 33 boxes.
With 24 it's 36 high
Would 18 stacked= 30 boxes if they were all in long position?
and 15=27?
SPAM rules!
  #47   Spotlight this post!
Unread 05-01-2003, 12:42
Ian Mathew Ian Mathew is offline
#0292 (Panthertech)
Ian Mathew is an unknown quantity at this point
Send a message via AIM to Ian Mathew
I guess technically that would be possible...but c'mon, 20 some boxes stacked up end-to-end where they aren't tapered or anything. It would fall and crush your robot...well, if they put weights in them it would.
Panthertech 292
  #48   Spotlight this post!
Unread 08-01-2003, 18:09
Rob36 Rob36 is offline
Robotic God
None #1189 (Breaking Pointe (Gearheads))
Rob36 is an unknown quantity at this point
Send a message via AIM to Rob36 Send a message via MSN to Rob36 Send a message via Yahoo to Rob36
wrong, much more points
Though basically impossible, the maximum amount of points that you are able to score is 1,112
First, you have a stack or 22 and 23 others in your zone (or the other way around), giving you 506 points
Then You must have both you and your alliances robot on top for 25 points each, 50 points total 50 + 506 = 556
Then as I read in the rules, if both members in the enemy alliance are Disqualified, then instead of doubling their total score, you instead double yours!!!!!!!!!!!!!!!!!!!!!!
506 x 2 = 1,112
I garuntee that nobody will get this amount due to not being able to stack 22 boxes, but it's still possible
There's actually a way to get more, but I forgot how
Any questions, ask me at I2ob36@hotmail.com
OR
IM me, my SN is I2ob36
  #49   Spotlight this post!
Unread 09-01-2003, 00:25
Cpt S.T.U.C Cpt S.T.U.C is offline
Cpt S.T.U.C is an unknown quantity at this point
If there's one thing I've learned over the years it's... If you think it is imposible, some other team will do it. Anyways, while design I came up with a system to lift almost 30ft. It would certainly be pushing weight restraints... not to mention every other part rule known to first. I wanted to build it just to watch it fall over during a match... hehe a 30 ft, 80 lb arm falling across that lexan siding of the ramp... SMASH! That's if it didn't collapse under it's own weight in the first place. But somehow I know some team will figure it out...
  #50   Spotlight this post!
Unread 13-01-2003, 16:11
Quentinfool's Avatar
Quentinfool Quentinfool is offline
#0217 (Thunderchickens)
Quentinfool is an unknown quantity at this point
remeber top qualifying score is one more point than other team not with one team getting blown out
"A strange game. The only winning move is not to play"-War games
Fantasy Football! EddieMcD Chit-Chat 176 30-12-2003 18:30
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
Chamionship Qualification - feedback needed ASAP! dlavery General Forum 97 11-10-2003 07:17
Seeding Calculations archiver 2000 50 23-06-2002 21:57
