Go to Post Don't tell the rookies to "not touch the robot", show them how to work safely. - Andy Baker [more]
Unread 20-02-2012, 01:54
DPG2013 DPG2013 is offline
FRC #4163
DPG2013 is an unknown quantity at this point
downloading my java code
[left]I'm having issues downloading code to my robot in Netbeans. It seems like it has something to with the frc plugins maybe. it says :
init:
init:
Deleting directory C:\Users\DJLoddiDoddi\Documents\NetBeansProjects\D orothyGilcrist2_021912\build
Deleting directory C:\Users\DJLoddiDoddi\Documents\NetBeansProjects\D orothyGilcrist2_021912\suite
Deleting directory C:\Users\DJLoddiDoddi\Documents\NetBeansProjects\D orothyGilcrist2_021912\j2meclasses
clean:
Created dir: C:\Users\DJLoddiDoddi\Documents\NetBeansProjects\D orothyGilcrist2_021912\build
Compiling 1 source file to C:\Users\DJLoddiDoddi\Documents\NetBeansProjects\D orothyGilcrist2_021912\build
compile:
Created dir: C:\Users\DJLoddiDoddi\Documents\NetBeansProjects\D orothyGilcrist2_021912\j2meclasses
preverify:
Created dir: C:\Users\DJLoddiDoddi\Documents\NetBeansProjects\D orothyGilcrist2_021912\suite
Building jar: C:\Users\DJLoddiDoddi\Documents\NetBeansProjects\D orothyGilcrist2_021912\suite\DorothyGilcrist2_0219 12_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[Including resource: META-INF/MANIFEST.MF]
Romizer processed 96 classes and generated 4 files.
Expanding: C:\Users\DJLoddiDoddi\Documents\NetBeansProjects\D orothyGilcrist2_021912\suite\DorothyGilcrist2_0219 12_1.0.0.jar into C:\Users\DJLoddiDoddi\Documents\NetBeansProjects\D orothyGilcrist2_021912\suite
Moving 1 file to C:\Users\DJLoddiDoddi\Documents\NetBeansProjects\D orothyGilcrist2_021912\suite
Deleting: C:\Users\DJLoddiDoddi\Documents\NetBeansProjects\D orothyGilcrist2_021912\image.suite.api
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) 64-Bit Server VM 22.0-b10
Target IP: 10.41.63.2
Network interfaces on host:
[CommView] Atheros AR9002WB-1NG Wireless Network Adapter: address: 192.168.1.76 netmask: 255.255.255.254
Atheros AR8152/8158 PCI-E Fast Ethernet Controller (NDIS 6.20): address: 10.41.63.10 netmask: 255.0.0.0 <--- on robot's subnet
Connecting FTP @10.41.63.2
C:\Users\DJLoddiDoddi\sunspotfrcsdk\build.xml:96: The following error occurred while executing this line:
C:\Users\DJLoddiDoddi\sunspotfrcsdk\ant\upgrade.xm l:40:
java.net.SocketException: Software caused connection abort: socket write error
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(SocketOutp utStream.java:109)
at java.net.SocketOutputStream.write(SocketOutputStre am.java:153)
at sun.nio.cs.StreamEncoder.writeBytes(StreamEncoder. java:221)
at sun.nio.cs.StreamEncoder.implFlushBuffer(StreamEnc oder.java:291)
at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.j ava:295)
at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java: 141)
at java.io.OutputStreamWriter.flush(OutputStreamWrite r.java:229)
at java.io.BufferedWriter.flush(BufferedWriter.java:2 54)
at org.apache.commons.net.ftp.FTP.__send(FTP.java:496 )
at org.apache.commons.net.ftp.FTP.sendCommand(FTP.jav a:470)
at org.apache.commons.net.ftp.FTP.sendCommand(FTP.jav a:547)
at org.apache.commons.net.ftp.FTP.port(FTP.java:872)
at org.apache.commons.net.ftp.FTPClient._openDataConn ection_(FTPClient.java:667)
at org.apache.commons.net.ftp.FTPClient.retrieveFile( FTPClient.java:1595)
at com.sun.spot.sdk.tool.ftp.UpgradeTask.checkVersion (UpgradeTask.java:34)
at com.sun.spot.sdk.tool.ftp.UpgradeTask.execute(Upgr adeTask.java:215)
at org.apache.tools.ant.UnknownElement.execute(Unknow nElement.java:291)
at sun.reflect.GeneratedMethodAccessor245.invoke(Unkn own Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.apache.tools.ant.dispatch.DispatchUtils.execut e(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:39 0)
at org.apache.tools.ant.Target.performTasks(Target.ja va:411)
at org.apache.tools.ant.Project.executeSortedTargets( Project.java:1399)
at org.apache.tools.ant.helper.SingleCheckExecutor.ex ecuteTargets(SingleCheckExecutor.java:38)
at org.apache.tools.ant.Project.executeTargets(Projec t.java:1251)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java :442)
at org.apache.tools.ant.taskdefs.CallTarget.execute(C allTarget.java:105)
at org.apache.tools.ant.Project.executeTarget(Project .java:1368)
at org.apache.tools.ant.helper.DefaultExecutor.execut eTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.module.bridge.impl.BridgeImpl .run(BridgeImpl.java:285)
at org.apache.tools.ant.module.run.TargetExecutor.run (TargetExecutor.java:539)
at org.netbeans.core.execution.RunClassThread.run(Run ClassThread.java:153)
BUILD FAILED (total time: 9 seconds)
Unread 20-02-2012, 05:45
linuxboy linuxboy is online now
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Re: downloading my java code
Do you have a firewall enabled on that computer? IIRC windows firewall can cause those sorts of errors. Try disabling any firewalls on the machine and downloading the code again.
- Oliver
Unread 21-02-2012, 13:54
FRC #4163
thanks that actually worked
