Go to Post The object of the team is not to design, build and compete a robot, it is to design, build and compete students. If after four years we have opened a student's eyes to the infinite possibilities they have in their life, it is worth all the effort. - adunakin [more]
Unread 20-02-2012, 08:03
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: 30 lb Withholding? for rookies?
Originally Posted by farmersvilleRob View Post
Could some please explain the withholding limit? We know the basics: 30lbs fabricated and unlimited on bought items and COTS items. But what does that really mean to a rookie team?
For example: Say we wanted to raise our bot up a couple inches. We would need a couple machined parts probably weighing 1lb max, some spacers, and some extra chain. Now the chain would be broken eventually so that's around 4 lb max of chain. So 5 lbs max fabricated we would bring, and some tools.
Is that legal? can we say that met the fabricated parts limit and COTS/bought limit? Also, are tool numbers unlimited on what we can bring? And can we cut/drill/sawsall anything in the pit? How/where would we do the fabrication on the actual machine and would we have to get it re-inspected everytime?
Can someone answer these questions for a rookie team? And don't refer me to threads. I know how to use a search bar.
No sparks or flames are allowed in the pit, battery chargers that are rated for >6amps are often not allowed, even if you promise to use them on a lower setting. -- your regional may provide a common machine shop where some tools and restrictions are lifted. Your pit is 10x10x10 with power provided, you can bring as as many tools as you want, and as much raw material, COTS and fabricated replacement parts as you want, 30lbs only applies to fabricated parts that aren't identical spares for what is already in your bag. While the pits are open you build/modify like it is still build season, except of course for the spark/flame restriction.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
